Hello,
I have a 1994 mustang gt with major speedometer and odometer problems. Neither the speedometer or the odometer has worked for a while. I pulled the instrunent cluster to check the worm gears many have suggested and found then in tact. I did however find a burnt wire on the back of the instrument panel that led to "battery" right behind the speedometer. I jumped the broken section of this wire and plugged it right back in the car and thought i fixed my problem until the unit immediately started to smoke.... Any ideas on what else i could try? (Fuses are still fine)
