  • 1994 - 1995 Specific Tech
intake manifold question
  • Thread starter Thread starter mustangking101
  • Start date Start date Sep 22, 2009
M
mustangking101
23
AZ
Sep 22, 2009
  • Sep 22, 2009
i want to buy a power plus intake manifold soon for my 94 stang. its only 300 dollars and it says it offers the same amount of horsepower as a edelbrock rpm intake so how much horsepower would that actually be? around 20hp? thanks
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Sep 22, 2009
  • Sep 22, 2009
I'm assuming you're referring to the Professional Products Typhoon? I bet you'd see 10-15 HP tops, but you'll probably lose your low end torque.
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Sep 22, 2009
  • Sep 22, 2009
Your heads, cam, intake should match for the best efficiency of making power. Combining parts that work in different "rpm windows" make less power than they should.
Im not gonna say to not buy the typhoon, but just dont expect it to perform at its best. But the good thing is later on when u upgrade the heads, your intake is already set to go.
Think of your final combination you'd like to have....and work towards it.
99FiveOh
2,051
20
99
J-Ville, FL
Sep 22, 2009
  • Sep 22, 2009
I'd be willing to bet in this economy, you could probably get your hands on an Edelbrock Performer for about the same price used. I had a performer on my last car with pretty much stock motor and I loved it! It definately had better low end than the stock manifold and it pulled nicely through the RPM range.
I hear mixed reviews on the Typhoon.. I believe it's a gamble as to whether you get a good one or one that needs a little work before installation.
Good luck!
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Sep 22, 2009
  • Sep 22, 2009
Good luck!
I got my polished typhoon used for $200 shipped.
And if u want a performer...then u dont "want" a typhoon. If u want a performer RPM...then u can consider a typhoon. Apples to apples.
Everyone says typhoons can come rough....but has anyone proved u need to correct one that has flaws? Before and after dyno/times down a track? Its good to say its in tip top shape, but at the end of the day if its only a small amount of HP thats affected.......u have to ask yourself does it really matter
Just looking for a bit more than people saying "oh its a gamble and u might have to correct a few things in the runners" and more like someone who ran it out of the box, had poor performance, went back corrected something, and got a gain out of it.
99FiveOh
2,051
20
99
J-Ville, FL
Sep 22, 2009
  • Sep 22, 2009
Not so much in the runners, I've seen first hand people install these intakes and not have them seal on the heads for crap. They ended up having to get the lower machined a little so it was flat.
And I understand that the Typhoon is a direct copy of the Performer RPM, but it was suggested and is common knowledge that the standard Performer is a better compliment to stock and near stock combinations. Unfortunately, Professional Products are too stupid to realize this and go ahead and offer a Peformer version of the upper intake. Either that or Edelbrock warned them to stay away from their designs or else...lol
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Sep 22, 2009
  • Sep 22, 2009
Both intakes aren't that hot. You can pick up a used Cobra or GT-40 for $200. Much better bargain I think.
Kurt
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Sep 22, 2009
  • Sep 22, 2009
Kurt
An explorer is in that ball park too....which can be had for about $150.
95Vert383AOD
1,133
34
69
New Bedford, MA
Sep 22, 2009
  • Sep 22, 2009
Used Trickflow Track heat...
Adam95GT
2,564
Burlington, NJ
Sep 22, 2009
#10
  • Sep 22, 2009
  • #10
Would suck with stock heads i think... but its a great intake
99FiveOh
2,051
20
99
J-Ville, FL
Sep 22, 2009
#11
  • Sep 22, 2009
  • #11
Kurt
An eddy performer has been proven many times to be a better flowing intake than any of the GT40 style intakes.
It's all about cost and what he want's to do. If he wants to tool around in a mostly stock ride, then the GT40 style intakes will do just fine. I personally had an Edelbrock Perf. on a N/A setup and a 15psi Vortech system and I loved it both ways..
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Sep 23, 2009
#12
  • Sep 23, 2009
  • #12
I'm sure it flows a little better, but I think the difference is marginal. I just think the Edelbrock intakes are a hassle to deal with.
Kurt
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Sep 23, 2009
#13
  • Sep 23, 2009
  • #13
Not trying to stir the pot or anything
but
I found a different kind of experience with my Edel intake
All I had to do was bolt it on
No valve cover issues what so ever
No spacer needed between the upper and lower
Grady
sl03gt
20+ Year Stangneter
Sep 29, 2003
182
Sep 24, 2009
#14
  • Sep 24, 2009
  • #14
I was told that quality is poor on the typhoons in general. The builder who did my neighbors motor said that alot of guys are bringing these intakes in with the heads to get done because of the price. Issues being sealing to the heads, extremely rough casting, and damaged threads that have to be helicoiled or tapped. Then on the elbow for the sn95 I saw in another thread that the opening narrows down. That is what I've heard.
Dino Dino Bambino
1,672
89
79
Cyprus
Sep 24, 2009
#15
  • Sep 24, 2009
  • #15
My experience exactly, and I bought mine from ebay for $182!
Yes indeed that's exactly what I've also heard. PP quality seems to be hit-and-miss.
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Sep 24, 2009
#16
  • Sep 24, 2009
  • #16
but
Grady
No, I totally understand, it's a decent intake. It's just that you have to pull that side plate off everytime you pull the upper intake, and you have to order a special gasket for the upper to lower. I can have my Holley intake off in 6 minutes, and I can get a new gasket with one trip to the parts store. The Cobra and GT-40 intakes are just as easy.
Kurt
99FiveOh
2,051
20
99
J-Ville, FL
Sep 25, 2009
#17
  • Sep 25, 2009
  • #17
You make an awesome point there Kurt, I did have that problem myself. I bought my Eddy second hand with no gaskets, so I ended up having to order them because I couldnt' find them locally.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Sep 25, 2009
#18
  • Sep 25, 2009
  • #18
Not tryin to be a know it all or anything like that
but
I don't have to get inside the plenum to install/remove my upper
I got the RPM not the Performer
Grady
Y
BBK SSI Crossover tube
  • yaboity
  • May 17, 2025
1994 - 1995 Specific Tech Jun 7, 2025
yaboity
Y
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
For Sale Hogans Racing Intake manifold for SBF
  • Bullitt347
  • Jun 7, 2025
  • Engine and Power Adder
Engine and Power Adder Jun 7, 2025
Bullitt347
351w turbo build.... Turbo guys teach me things...
  • Kid wita 5oh
  • Oct 22, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 23, 2025
General karthief
