Hi, with a 347, twisted wedge heads, ?cam, some people said I should go with a Trick flow type R manifold, but looking at the specs I am kinda having second thoughts
* Large cross-section 12.000 in. runners
* 2,500-7,250 rpm range with 75mm upper
* 3,000-7,750 rpm range with 90mm upper
* 75mm or 90mm throttle body inlet
* 2.000 in. x 1.200 in. port size at cylinder head
* 11.000 in. overall height to the flange
above is the specs for the type r manifold.. doesn't that seem like a bit much for a mostly street maybe some light track car...
Seems like people are falling for the good old bigger is better thoughts.... starting to look at something more practical..
Here is the track heat specs:
* Small cross-section 12.200 in. runners
* 1,500-6,500 rpm range
* 75mm throttle body inlet
* 10.200 in. overall height to the flange
and the street intake specs:
* Small cross-section 15.000 in. runners
* Idle-5,500 rpm range
So with the track heat intake will it always rev at 1500 rpm, and with the type r will it always rev at 2500 rpm?? I think 1500 seems acceptable...
