Intakes
LIZARDKING
21
14
28
Hell
I still havent seen an intake worthy of my $.
I dont care for an open element air filter.
I was hoping that Volant would come through for us by now. I e-mailed them last week, no response.
No sense buying a tuner, until I Identify the intake.
So now Im thinking that I may go with a GT setup. The airbox bottoms are the same, I would just need the top and the GT MAF, and the pipe between the MAF and TB. Im sure I can adapt something from Pepboys or Advance.
If that setup is good for 300hp in the GT, it should be more than adequate for my V6.
When I buy a tuner I can have it calibrated for the GT MAF.
It would be much easier if someone would make a decent closed filter intake for us.
So a pricey Volant would be worth your money???
Why not run a new, non-corrogated tube from the TB to the stock airbox, and then enlarge the hole that feeds air into the bottom of the airbox?
A Mustang mag(MM&FF?) did a test on all of the available CAIs for the GTs and the C&L was rated the best. I have the Steeda but I'm thinking of getting the C&L instead. scrming already switched to the C&L. I'd recommend getting the C&L and SCT-2 from BamaChips, he has a great tune for them.
Excepcion13 said:
That MRT one looks nice! What is superior about the closed vs. open or is it a style preference?
MM&FF said the the enclosed air box is a must have when they did their test. Think about it, the whole idea of a CAI is to get cold air into the engine. The heat shield does just that, keeps the hot engine air out of the intake.
Bama-Chips is back in business now? What's the damage for the C&L and SCT-2 set-up?
The C&L and Bamachips X-cal II tune are very, very impressive!
MM&FF said a 'Shield' is a must, not a closed airbox.
There is a good comparison article on my site www.DeMolet.com as you scroll down on the entry page. This compares the system to the C&L (article link is just under 5.0 Mag pic)
Have the filter breathe.
Go with a system that elicits excellent tuning.
The V6 is a single TB. You don't use a dual-TB GT system with a single TB. You'll loose velocity plus the TB coupler would be sized for a twin TB. Bigger isn't always better.
I sent one of my new V6 CAI / NGK iridium / Xcal2 packages this past week for dyno testing and I'll post the results.
hamidlmt said:
whoops... sorry... meant to post prices but forgot...
X-cal II from Bamachips... $384 including shipping
C&L intake directly from C&L... $308 including shipping
Ok, I thought BamaChips was offering a package. If they aren't, they should.
cjmorrell said:
I'm working on a package of: JBA Evolution exhaust system, SCT tuner and K&N intake. Any thoughts?
The jba's are great, as is the SCT. The K&N intake doesn't require a tune. Doug at Bamachips thinks an intake that doesn't require a tune isn't really going to make more power with a tune. I trust this guys opinion... he's been tuning 4.0L's for years. If you're getting an X-cal, might as well get a higher performing intake.
Thanx for the input. I msut agree with you. I'll have them change the intake to C&L, that was my first pick, but they suggested the K&N because it didn't need a tune, and less prone to heat sink.
