My 95 Gt is throwing an intermittent CEL. It does not have a code. I have had several different shops scan this car, with the light on and when the light is off. I have played the guessing game and replaced O2 sensors, EGR valve,throttle position sensor, air idle control sensor, coolant temp sensor, distributor, coil, fuel pump, and engine management control solenoid (ccrm).
I've heard of a loose ground wire at the fuse block might cause this. Does anyone have any insight to what the answer could be?
ty cold air intake, but it uses all the stock sensors and is sealed very well. I thought there might be a vacuum leak so I went over that and made sure. I have a MSD 6A box. And some suspension mods. Other than that the car is stock. When the light is on it goes into a limp mod and the engine timing goes off. Loses power and all the valves rattle under acceleration. When the light is off, it runs great.
