Hi Guys.
I have 10" of vacuum in the crankcase measured through the dipstick tube and when i remove the oil fill breather the engine will stumble and die.
I have 16" of vacuum in the manifold, I'm getting ready to remove the carb and valve covers to check the gaskets, and maybe the manifold, already replaced the pcv valve and also the oil fill breather-open type. just wondering can the engine have an internal leak somewhere?
Engine is a recent 289 rebuild with a 302 rotating assembly, using 86 e6se heads and an 84gt manifold making up the core engine parts, along with a 62 4100 600cfm carb.
Also a little off topic, but once i get the leak fixed is the 4100 a good carb to use or should i go to a smaller carb like the holley 390cfm(the cam is a mild one-crower#15206) for improved throttle response and mileage etc.
Thanks/Steve.
Thanks/Steve.
I run my PCV systems all the time with an open cap. Never was a problem. The PCV valve itself is the check valve for the vacuum leak. The setup on my Ranger is different from any other, the valve covers have two holes each. I run a PCV valve in each in the front hole and the two rears are run to a "T" and the fresh air is drawn thru one of those "ricer" style vavle cover filter caps ( these are sold in the ricer section at the local Advance Auto Parts) The cap/filter is hidden behind the carb. The PCV's are also run to a "T", then into the carb base.
