is it possible to hit 80???????
superslothguy
103
ok last night i ran at irwindale and i hit 78.63 mph and i have stock gears with the new micky tompson et street raidials and i wana know if its possible to hit 80
my mods are jba shortys,flowmasters,bbk cold air,14* timeing,bbb underdrive pulleys,micky tompson et street raidials
my question is can it be done? and how should i drive it? what should i launch at and every pointer u guys can give me would help thanks.
i would think so , not a lot of guys run 1/8th mile and w/ stock gears your gonna be in a bad spot..prob about 3 grand in 3rd? through the traps?
the stock tach sux but try to start your shift at about 5200 and you'll finish it by 5500
what kind of 60' times do you have? doesn't matter much on mph...but if your hooking try to launch about 3500 and powershift all the gears.
maybe your going through in 2nd but i doubt it. anyway...unless your already driving the car to it's full potential...you should be able to get 80..if not try the bottle
My friend ran 82 MPH in the 1/8 with his bolton 87 GT. Stock intake, tb, 3.08 gears, stock cam. Car was STRONG for what it was and he drove it as hard as he could. MPH is an indicator of power, if you bog, forget it, it's gonna suck, if the car is heavy, it's gonna suck, if you dont shift fast, it's gonna suck. You might wanna try to shift around 5000-5200, they dont make any power past that anyway.
I ran almost 81 MPH in my 88 GT that had all the boltons and a Explorer Intake and Crane 1.7 rockers on MPH killing ET Streets in August. It was HOT and HUMID, with some more practice runs, I could have ran a bit more than that in good weather.
Speeds8erM-1 said:
2.73's will hurt you bad, 3.08's, even though it isnt that much of a change would actually run alot better. 2.73's put you through the traps at some weird RPM's.
when i ran at the dale with stock gears i was wayyyy ovver revving 2nd (76mph) :nonono: now that i have gears, i go through the traps in 3rd around 5200 or so :nice:
Yep, Im not a fan of putting alot of gear in a stock cam and intaked Mustang and think 3.08's or 3.27's work good all around and still work decent on the street from a roll, the 2.73's just suck. They make everything odd. Just like your results, second gear through the traps, bleh. 2.73's suck!
My Powerdyne car had 2.73's, it was a major pig down low, from a roll on the highway, it moved good even for the low power it had.
i disagree on that one...i think gears and heads are two best gains other than nitrous that money can buy
my stock motor (comletely stock H/C/I) notch ran 13.20's at 102 w/ 4.10's
all stock everything , just 4.10's and tires it went 13.80's or 13.60's
added the lca's and 75 shot and it went 12.50's....still stock long block
Well of course heads make a huge difference, heads and cam make all the power. Gear wise, I dunno, my friend showed that you can use 3.08's in his car, it ran 8.42 in the 1/8 in his 87 GT with stock heads, cam, intake, tb and fan with 3.08's. Stock 200000 mile long block. He used to bury other mildly modded Mustangs on the street because all they would do is shift, fall back, shift fall back. 5000 RPM 302 dosent need alot of gear unless you are trying to launch HARD on some good tires.
