i have a new heater core in my car. i was not getting heat out the vents. both lines were hot at the firewall. so i was told i either had some clogging or an air bubble in there.
so today i went to remove my lines off the firewall, and it ripped one of the fittings out the heater core. is this ruined? can you mend the fitting?
i put it back together and it was slowly leaking from the fitting that did not come out. they both wobble around pretty loosely, but the one will pull out and push in further then it use to.
am i doing another heater core or do i have another option?
iac is clean, tps is set, maf is new/clean, new alt charging properly, all vac lines connected, cleaned salt/pepper shaker connections, its all grounded properly, fused power wire off alt. i dont know anymore.
