Is there a JunkYard thread yet?
darthcual
985
Arlington, TX
As the question states, have we started a J/Y thread of all the interchangable parts from different cars. I cant find it if their is. Maybe a sticky is in order? This stems from the fact that I was trying to find an 8.8 rear and i found a couple for 30 dollars with the 5 Lug and was wondering if my 4 Lug axels will fit? I have no idea what vehicle they came off of other than that they are ford rears.
Lincoln MK7/Continental rotors will convert the front to 5-lug (and they also use the SVO rear disc setup, and most use the SVO aluminum MC).
A 4X4 Ranger rear end will get you decent gears in a 31spline 8,8" chunk, and a pair of drivers' side axles will convert a Foxbody 8.8 housing to 5-lug.
Areostars use the same rear as a ranger, but most are open units with crappy gears (and porbably 28 spline). Note that a majority of Rangers/Areostars use the wider 2" wide drum setup also.
Mk7/Continental chunks are usually posi, but the gears may suck, and I'd guess they're 28 spline (too lazy to go look :D)
Somewhere on the net are measurements of Ranger short-side axles, so you could check the length of the unknown ones you found.
A visual ID tip: Ranger/Areostar rears are a little over 57" axle flange to flange and one side is visibly a lot shorter than the other.
For other upgradable items from other FML's, Jrichker has a post with that info (TC rear ends, SN95 TB's, etc).
Good luck.
