is there a oil pump-to-block gasket?
rockin_rick
968
I went to my local ford dealer and asked for a oil pump to block gasket (among other things) and I was told that it didn't show one, therfore it didn't use a gasket. Is this correct?
Rick
I had an old International Loadstar 1600 with a 345cui, I changed the oil filter bracket and it didn't take a gasket either. I was surprised. It doesn't leak though.
I did spray both sides with gasket sealant though, to kind of seal up imperfections between the surfaces. The bracket I used was a used one.
o yeah a new pump comes with 2 gaskets pickup to pump and pump to block. just bought one the other day. my car looks stock internally but has a double roller timing chain. was that stock also?
Thanks for the replys, guys. I will do the gasket (and I will sleep better at night). I just don't trust the parts counter guys, especially with something as critical as my oiling system.
Rick
I just got my M-6600-M50 production oil pump and it only came with 1 gasket. It looks the same as the gasket I got from the dealer for the pickup. It will fit the 3 holes fine, but it doesn't cover the entire mating surface.
After some thought, I think that I will NOT run a gasket. I think that the pump will be more stable against the block without the gasket. This may be a non-issue, though. Of course potential leaking is not a concern.
Thats my 2 cents. Thanks to everyone for their input.
Rick
