I've used the FMS, MSD, and Livewires and wouldn't mind using anyone of them again. I stil haven't used Taylor, tho. Do they all conduct the same spark or is one better than the other?
Thanks
Thanks
not calling BS but how do you know this for a fact?Pennywise2 said:The MSD plug wires have the least resistance and give the most voltage output.
I Ohm tested all of my MSD wires before putting them on the car and they had significantly less resistance than the FMS wires i took off and the old stockers i had laying around. wish i had of had some livewires to test at the same timePennywise2 said:The MSD plug wires have the least resistance and give the
In auto shop for one of my tests in my senior year in high schoolBlackVert said:not calling BS but how do you know this for a fact?
Pennywise2 said:In auto shop for one of my tests in my senior year in high school
I had to test the resistance and output voltage of different spark
plug wires and see witch spark plug wire had the least resistance
and the most output voltage.I tested the Taylor 409's,Livewires,
MSD's,FRPP's,and stock Ford OEM plug wires.Here is what I found
was the best in numbered order.
1.MSD spark plugs (best output voltage and least resistance)
2.Livewires (almost as good as the MSD's but,more resistance)
3.Tayor 409's (close in voltage to the Livewires)
4.FRPP plug wires ( just a little best than stock in resistance and output voltage.
5.Stock Ford OEM plug wires (Alot of resistance and output voltage was
horrible)
After the test I returned all the other plug wires and keeped the MSD spark
plug wires and my auto shop teacher gave me a A+ .![]()
Therian said:livewires all the way...LTs eat many other wires
