im having driveabilty problems after i did my battery relocation, immediatly AFTER my battery relocation my car started acting funny, 90% of the time the car runs fine, then the next thing you know it goes dead rich while cruising down the road, we're talking going from a A/F of 13.7 at cruise to 10.0-11.5.........at a cruise?? it also does this at idle too, then other times it will run lean, and then back to normal??? Pro-M recommends a 10ga ground directly from the battery NEG- up to the original ECU ground, could this be my culprit?
Thanks, Scott
Thanks, Scott
It did not change when you moved the throttle open. After I grounded the Air Intake Temp sensor the TP started to work again. I guess it is tied in with it.
i have a digital volt meter and im ready for ANY info you have.
