is this a good topend for a 347
oldno7
109
i was looking at getting these things from mustang unlimited in a month. will this be a good set up.
Afr 1420 heads
xtreme energy hydraulic cam cc3518
PRO MAGNUM ROLLER LIFTER RETROFIT cc8931
TIMING SET HI-TECH DOUBLE ROLLER cc3138
ROLLER ROCKER SET ULTRA PRO 3/8" 1.6 cc1631
you think this set up. will this work with a 347 stroker and my setup already. is there someting that i might be missing.
I'm guessing the 1420 is just the model number for afr 185's?
If you are dropping the money on the afrs, might as well get a custom cam.
You may also want to do a spring upgrade.
I see no mention of a new intake, consider a victor jr efi.
The cobra is definitely undersized, ported or not.
I'm not overly familiar with those valvetrain parts, just check reviews to make sure the brands are a good quality.
You are going to need to have the maf recal'ed and get some 30's. Yes, 30's will work in a NA situation. You do NOT need more without a supercharger, regardless of what these guys tell you based on ratings and charts.
