is this a problem??????????
  • Thread starter Thread starter jimc347
  • Start date Start date Nov 29, 2005
J
jimc347
77
  • Nov 29, 2005
can u guys tell me if this setup is good? first i need to ask why c&l are bad? i do have a 73mm with 24# injectors it does idle crappy. mods are 302 stock bottom end tfs heads, stage 1 cam, upper and lower intake. besides the c&l being crappy i have a 70mm throttle body 70 mm spacer going into a 73mm tube?? this is the way i bought the car.?????????? what needs to be changed??
Dbeck002
710
South florida
Nov 29, 2005
  • Nov 29, 2005
i have an almost identical setup.
73mm CL
70mm TB and spacer
Aftermarket heads (AFR)
My car idles anywhere between 700 and 900. it goes up and down. does yours do that?
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Nov 29, 2005
  • Nov 29, 2005
Many people have problems with the C&L meters on their cars. Is your stock air box still hooked up? If your just have an air filter attached to the MAF, that is surely causing your problems. If that isn't the case I'd say the meter is causing your problems.
AT the top of this forum (5.0 Tech) is the best write up on surging idle. Run through those things and if you still have trouble it'll be time to change out your C&L.
Daggar has a link to the new Pro-M site in his signature. That would be the company I choose to replace my bad meter with (If I was you...)
J
jimc347
77
  • Nov 29, 2005
yes i checked everything and all is good. and yes my idle is all over the place. i just changed the mass air and still idles f--ucked up.
J
jimc347
77
  • Nov 29, 2005
oh i just have a big ass air filter at the end.
srothfuss
Oct 17, 2004
1,796
Woodward Ave.
Nov 29, 2005
  • Nov 29, 2005
Are you running a mechanical fan?
If so: The air that the fan is moving is being sent through your open air filter (not closed off to the engine bay) and passed the MAF. This extra air is what will trigger your idle problems. I would suggest that you should look for a stock air box on eBay or Fenderwell kit for your air filter.
If not: Have you tested for vacuum leaks?
Edit: Grammar
J
jimc347
77
  • Nov 29, 2005
do i need to change everything from the airfilter to the spacer????
srothfuss
Oct 17, 2004
1,796
Woodward Ave.
Nov 29, 2005
  • Nov 29, 2005
You only need to add this part of the system. (Either a stock box or kit that moves the filter into the fender and out of the engine bay.)
J
jimc347
77
  • Nov 29, 2005
yes it is a stock fan.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Nov 29, 2005
#10
  • Nov 29, 2005
  • #10
Sometimes a simple shield out of sheet metal or gutter flashing can block air wash from the cooling fan. Remember, when you move only the filter to the fender well, yoiu have an elbow in front of the meter - and that impacts the way it 'reads' the flow as well.
J
jimc347
77
#11
  • Nov 29, 2005
  • #11
yes i was thinking of that. i think i will make something and spen my money on the pro-m tube.
aod92
104
#12
  • Nov 29, 2005
  • #12
I had a c&l on my car and it idled like crap. When i changed to a pro-m my idling problems were fixed.
J
jimc347
77
#13
  • Nov 29, 2005
  • #13
thats what i'm thinking i just blocked off the side of my air filter and no change. going for the pro-m
srothfuss
Oct 17, 2004
1,796
Woodward Ave.
Nov 29, 2005
#14
  • Nov 29, 2005
  • #14
This would probably be the most cost effective way to verify that the fan 'wash' isn't causing the problem. I never thought about that. Very good point indeed.
Again, very good point. I wonder if this has anything to with the 'power pipes' actually making more power over the typical fenderwell CAI.
just4bob50
504
Pa.
Nov 29, 2005
#15
  • Nov 29, 2005
  • #15
My brothers C&L 76mm never ran right, and he bought a pro-m. After the pro-m his car ran great. My friend had problems with his C&L meter and all he ended up doing was clocking the meter about 90 degs. clockwise and it pretty much got rid of his idle problems.
Curse
791
El Paso, TX
Nov 29, 2005
#16
  • Nov 29, 2005
  • #16
I had to clock my C&L so my car could idle somewhat ok with an open K&N on the meter. The crazy part is on my friends mustang with my C&L his car idled/ran great.
J
jimc347
77
#17
  • Nov 30, 2005
  • #17
why is that? how could it work on one car but not the other?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Nov 30, 2005
#18
  • Nov 30, 2005
  • #18
For the same reason one girl is prettier than another ...
It just happens...
J
jimc347
77
#19
  • Nov 30, 2005
  • #19
well today i adjusted my idle, set tps. the idle is alot better but it could be better. it still lopes alittle has to be the ****ty c&l tube. and i fixed the o2 problem the cause the pvc popped out caused it to run lean.
  • Mindseye007
  • Aug 16, 2026
Mindseye007
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
C
Dyno day! # guesses?
  • clayton seiders
  • Aug 15, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 16, 2025
Scrapla347
SOLD Trick Flow Box R Series Upper Intake w/90 mm Inlet
  • Habu135
  • Apr 30, 2026
  • Engine and Power Adder
Engine and Power Adder Aug 19, 2026
Habu135
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
