is this an fms f cam and also an opinion
91lxntch
247
altoona,p.a
i am installing my h/c/i and the old cam has f303 stamped on the end which im certain is for the fms f cam but just to be sure is this correct? also would you run the f cam or stage 1 trick flow with...
trick flow heads
intake
rockers
70mm t.b
76mm c&l mass
30#inj
255 pump
373 gears .....it will have a vortech s trim on it as well.....
trick flow heads
intake
rockers
70mm t.b
76mm c&l mass
30#inj
255 pump
i'd use the f 303 with a blower,jus me
