Yesterday I installed Trick Flow Track Heat upper and lower intakes, Granatelli MAF, and BBK 70mm throttle body. On the first start up attempt, we couldn't get the car started, which ended up being the coil wasn't plugged in
(I don't know how I missed that, but I did). Anyways, I think there was a little too much fuel in the cylinders from the multiple attempts to fire, however it started right up. I started it and let it run for a few to try and burn out some excess fuel and then the problems started. The car idles just fine until you touch the accelerator; even the slightest touch kills it. After starting it and killing it 2 or 3 times, I said forget it, it's been an all day project I'll mess with it tomorrow. I started it up again today and it fired right up, and as soon as you hit the gas, it dies. I rolled it into the driveway and fired it up again and revved it a few times to about 3k and it will run until I let the rpm's back down and it dies. This time I fired it up again and held it right at 2,000 rpm and it runs smooth, doesn't seem like it's missing or cutting out, and I would have thought I'd burned any excess fuel out by now. Again, when I let off the gas after holding it at 2k, rpms dropped back to idle and then it sputters and dies. I'm completely confused as to why it will idle on its own, hold it's own at 2k rpm, and anything in between kills it. The MAF is a 75mm for 19# injectors. I didn't see any reason why this setup wouldn't work, based on parts compatability and other guys who have bought the same parts or ran a similar setup. Any ideas????
