It slipped at the race
68conv4sp
270
Went to an autocross event with my 68 last weekend. Car was performing like a slot car until the right front camber eccentric worked loose. That was it for the day. The alignment shop reset it all for me, but what can I do to prevent a similar occurrance next month? Is tack welding really the best bet, or is there some less invasive method?
promotorsports in sandy utah has the eccentric eliminators. they just bolt in place of the eccentrics. if you want to go the cheap route, you can tack weld the eccentrics in place. that way they can still be broken loose for alignment settings. or you can weld them permentantly and use the older tried and true method of using shims to align the front end.
I have a set of the Eccentric Eliminators. They are awesome, I would reccomend them.
Also, I am interested in the boss 302 handling guide. Where can it be found? I tried google real quick, no dice. Is it on paper only or?????
I have these as well good product http://www.pro-motorsports.com/?page=prod_aeek
