Going to change UCA & LCA, need advice on where to jack the car up ( I have 2 floor jacks ) and where to place jack stands to support car
According to the CHE performance website. They do NOT recommend supporting the vehicle at either the LCA or UCA locations. Their instructions clearly state.
With the rear wheels properly blocked, raise the front of the vehicle, and support it with jack stands along the structure of the vehicle. Because you will be removing the bolts that attach the front A-arms to the k-member, do not support the weight of the vehicle at the wheels or on the control arms. The front wheels should be hanging freely above the floor.
I don't think we are talking about front LCA's here. But your correct. To do the fronts you would have to support the car on the frame.
The springs are what hold the car up, so I dont' see why not. The LCA's and UCA just locate the axle more than anything.
That's correct. I've got this process down to literally a 30 minute job on LCA's.. Do one side at a time and next to no movement occurs with the axle.
I would also like to clear up, that if My Yellow Stang had specified, he was referring to the rear LCA/UCA's. I wouldn't had misinterpreted his question, to begin with.+1!
...but thanks red05bullitgt for clearing it up for anybody wondering out there![]()
