Junk Yard Dog is alive!
1WildII said:
cool, no you didn't bombard me, I like to learn about mechanics. It looks like I'll be a little busy with the advancing problem, but as for the tranny leak it turned out it was just the cooler line wasnt tight, so I simply took it off teflon taped it and put it back on tight enough.
My motor is from '74 and it only has one vaccum line, it also has an edlebrock intake and 4brl holley.
I took out the motor to swap it into my new body, so all I did was clean it up and re-paint it, it had a recent over haul so it was good to go.
I set the timing for 10 degree advance.
When I wired it up though I did it wrong off the plug that comes off the distibutor (the plastic plug broke so I had 3 stray wires) I switched the 2 colored wires by mistake and it through sparks from the solenoid when I attempted to start the motor. Could that have affected anything?
thanks for all the help,
Chris
It's possible you might have done damage to the elec. ignition box, but unlikely since it is running. You must be using the distributor that had came with the car or one like it because The first year for Duraspark was 1975. That's fine cause all the DS distributors will interchange. But in your situation, usually if you short out the ign. box, it won't run at all.
On your carb, make sure you got a vacuum line going to the port on the metering block on the passenger side of the carb. The metering block is a part of the carb that is a little over 1/2" thick and sandwiched between the fuel/float bowl and the carb body. The port will be just infront of the Choke assembly, if equipped. Now- You can run without the advance hooked up. If the diaphram is bad on the distributor this will be a vacuum leak when throttled. You really only see the affects of the vacuum advance when the engine is accelerated under a load. Running static (not driving) the throttle should be snappy reguardless.
I'm gonna have to go with Wart on this one. Sounds like you could have more gremlins in the carb itself. If gas has been sittin in that carb for a while it (you dodn't saw if it was new or not) can do untold damage. Be sure to check and make sure all the ports on the carb and intake are plugged and the base of the carb is tight to the body and the carb itseld is cinched down well with a good gasket. Are you getting any vacuum draw from the port the advance hooks to when idling?
my computer died but now I'm back.
Im not sure if there is vaccum or not, right now a new problem has arose, it wont even start, I figured it to be the solenoid becuase I can jump it and it turns, but then I got a new solenoid and it still wont start by the key, if I can fix this I can tell you if there is vaccum from the port! This is driving me crazy I'll tell you!
Chris
Do you mean jumping between the battery andthe S terminal, or do you mean bypassing the solinoid completely?
Does the car have power?
