just got my mustang back running
Cam question
You mentioned having 92 heads and a Comp 31-432-8 cam. According to Comp, that is a not a valid combo.
The 31-432-8 cam if for older blocks that didn't come with a roller cam from the factory. The 92 block DID have a roller from the factory.
The 31-432-8 cam is a reduced base circle cam. A roller block like yours uses a regular base circle cam.
Are you sure on your Comp cam part number? Please check the actual part number you bought and list it here.
I have an old 1971 302 block that I want to use a roller cam in. According to Comp. I need the 31-432-8 cam.
Thanks.
Danford1
"You mentioned having 92 heads and a Comp 31-432-8 cam. According to Comp, that is a not a valid combo."
I could be wrong but it looks like he said he had 84 heads
