  • SN95 4.6L Mustang Tech
Just ordered the MGW Shifter.
  • Thread starter Thread starter Fast02
  • Start date Start date Nov 12, 2004
First Prev 2 of 2
M
Mustang_GT_02
124
#21
  • Dec 8, 2004
  • #21
just a question from where can u order one?
Fast02
239
#22
  • Dec 8, 2004
  • #22
Follow the hyper link above to purchase one.
I installed it. Simply amazing. They should name it the T2. Talk about solid. Felt like I was shifting a race car. Going from gear to gear is very short and if its quiet you can hear it click into gear and into neutral and into the next gear. There is a little gear whine when decelerating at low RPM sometimes.
There is Zero play throughout its range. 1st,2nd,3rd & 4th are so close together that you just shift up and down with no side to side movement. I dont know if im not used to it yet or not but 5th gear almost seems like its a black sheep and off to the upper right compared to the tightness of the first four. Oh yeah and as I was banging through the gears at WOT I felt the shifter bottom out on the stops.
I think I will order up a Red handle as this blue one is pretty short and I like to ride gangstah...
The quality of this part makes me proud to be an American.
I did take some install pics and will post them tomorrow night.
Instructions were very exact and you really cant go wrong, I have never changed a shifter and found it easy to do with the instructions in my hand.
I had an extra two nuts with lock washers left over and dont know what those are for...into the nut box they went. haha
Spreadman
two wheels
Houston, TX
Dec 9, 2004
#23
  • Dec 9, 2004
  • #23
What Fast02 said was pretty much my reaction. Words can't describe how much better it is than a Pro 5.0 or Steeda.
With the Pro 5.0 I always felt the springs weren't stiff enough. I broke a shift fork in my tranny because of this. I pushed hard into 3rd, and it got caught halfway. Not the shifters fault, it was my fault for trusting it.
MGW's springs are progressive, and are MUCH stiffer. He tore apart 3 aftermarket shifters.....and made a shifter that excelled at everything. The construction is bar none, the shifts are shorter, TRULY shorter, and you have full 360 degrees of adjustment with the shifter handle.
Love it.
87 blown stang
139
pa
Dec 9, 2004
#24
  • Dec 9, 2004
  • #24
5th is way on over there. it's just that 1st thru 4th are so tight
M
MGWLTD
82
georgia
Dec 9, 2004
#25
  • Dec 9, 2004
  • #25
they go on the ends of the stop bolts to lock them in place. just in case the setscrew on top lossens
regards
george
Fast02
239
#26
  • Dec 9, 2004
  • #26
DOH!
Fast02
239
#27
  • Dec 9, 2004
  • #27
Ok, so let that be a lesson to you kids...dont forget the jam nuts on the stop bolts.
here are some pics I took. As you can see the stocker is indeed a POS.
here are some side by sides to compare, note the black cup still attached to the stock shift ball. You will need to use caution as you pry this off with a small flat blade screwdriver...its just plastic, mine popped right off with ease.
People must think im on Prozac because im always smiling when I drive my car.
Thanks MGW!!
Fast02
239
#28
  • Dec 12, 2004
  • #28
If your 6ft and your seat is all the way back then you may want to go with the red handle (longer) shift handle.
F
FalconGuy016
437
Northern VA
Dec 12, 2004
#29
  • Dec 12, 2004
  • #29
I worry about that, im 6 ft and my seat is all the way back. Will I lose much performance with this?
First Prev 2 of 2
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Sep 7, 2026
AeroCoupe
Progress Thread Progress Thread- From6to8's 1994 Cobra Supercharger install
  • from6to8
  • Sep 25, 2025
  • 20 21 22
12K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
  • D Durden
  • Oct 20, 2025
  • 2 3
4K
P
Transmission to radiator connection
  • P0nyRider
  • Aug 5, 2024
1996 - 2004 SN95 Mustang -General/Talk- Sep 23, 2024
4gwenddolau9
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
