just returned from the track what u think?
stanggt00
371
baltimore md
ok just returned from the track tonight and the more i go there the more i see that i am the weakest link to my goal at a fast car lol.
anyways i got there late so i was only able to pull off 2 runs....
this is my fist time with drag radials
60' -----1.950
330 -----5.793
1/8 [email protected]
1000 -----11.362
1/4 [email protected]
the car bogged every gear i was shifting way to early (big diff from street tires)
second run still tring to feel the car out
60' -------1.969
330 -------5.777
1000 ------11.082
so all in all i see i need more time behind the wheel and a shift light would be nice also
but seems the car is very strong i think i could have pulled off a 12'sec run if i had a few more runs my be next week when the 3.73 go in and the 4.10 come out..
for that last run i toke here all the way to 6700rpms in 4th i was smacking the rev limiter but i was at the end of the track by then..
4.10's is just to much gear for a blower car some like it but i dont..
as for tires i am running my bullit 17 X 10.5 rims with nitto 555r drag radials
i am mostly going by feel when it comes to launching the car
but what are u guys launching at with drag radials
it was 3k for me on street tires.....
I assume 315's nitto's? Yeah that last run trapping 116 is pretty stout! I hope I can trap 115+ when I go, but in reality I would like a 120 trap after a few fixes this fall:nice: Yeah it def. takes time to feel it out, but those 3.73s will help, unless you just go with a 28" tire
i want to keep it a street car
any one know the smallest pulley i can go before i need a 8-rib i want to max out my sq-trim i want 15-16psi out of the little sq-trim
i will be ordering the paxton fmic monday..
i think i will need a upgraded blow-througth valve.....
smallest pulley i saw for sq-trim is 2.87
hell with it i will just order the 8-rib kit also for 550 bucks that should cover slippage on a small pulley size
The mph is there to run high 11's! I ran 11.90 @ 114 mph so you could definately go 11.8x's! You must have been winding her up pretty tight to trap 116 w/4.10's. Unless you have a taller than stock tire.
Yeah, that is true.
If you get the driving part down you can get a great E.T. from 116mph.
hehe my mods are :
mmr900 shortblock
patriot stg2 heads
mph blower cams
sq-trim vortech 3.6 stock pulley
cobra fuel tank and pumps
kb boost-a-pump
full performance exaust system :lt headers,0/r x-pipe,catback
bbk upper intake w/ 75-mm tb
hehe my mods are :
mmr900 shortblock
patriot stg2 heads
mph blower cams
kb boost-a-pump
Might as well go 8 rib and let it fly! 600 here we come!:nice: You running 60's or bigger?
Hell yeah! I would definately go 8 rib and crank up the boooost!
Might want to consider either a P-51 or TrickFlow intake manifold while your at it! Let it eat!!
thxs guys sounds like i could be on my way
she only has 42lb injectors atm but i am sure the guys at jpc will let me know if i need more..
the devils at the door i think my wife is going to shut me down on all the spending lol..
so i am ordering the intercooler monday and have jpc put it in along with my 3.73 gears ...
and mybe i can get the wife to by me the 8rib pullies for my birthday wish me luck :nice:
Good traps. I would at least go to a 3.1" pulley. I ran a 2.8" RR pulley on a 6 rib. Only spinning to 6200 I made close 13psi through a cheap ebay intercooler and stock heads with a V1. The V2 has a slightly steeper step up ratio so you should see more with a less restrictive intercooler. With that I made 516whp and averaged 125-127 traps.
