  • SN95 V6 Mustang Tech
K&N worries
  • Thread starter Thread starter spetz
  • Start date Start date Jul 12, 2006
spetz
15
  • Jul 12, 2006
Just installed a new k&N intake. All the hoses are nice and tight. Should I really have anything to worry about. When I reconnected the battery and started my car it started a tiny bit slower. When you disconect the battery will it mess with your computer a bit? Is performance a little bit different for a little while?
ChingonStang
308
Dallas, Tejas
Jul 12, 2006
  • Jul 12, 2006
Wierd. Performance should better. I didn't have any problems with mine, but I only used a K&N drop in filter.
Yellow_V6
55
Colorado
Jul 12, 2006
  • Jul 12, 2006
When I changed my filter I turned the key and I saw my speedometer and tack go all the way around confirming the restart of the computer so I think mine might have taken and extra second or two to start up but nothing more and there shouldn't be a decrease of power or preformance check your house and make sure that even though they are tight that they arent pinching of anywhere. I had to lengthen on of the houses on my car because if I didnt it would have been pinched off.
Adverse2Change
340
Raleigh, NC
Jul 13, 2006
  • Jul 13, 2006
What you experienced is normal. Having the battery disconnected long enough will reset the computer, and give you that first start roughness. Nothing to worry about, as the computer will start learning about the new airflow.
Skymarshal
572
Dallas
Jul 13, 2006
  • Jul 13, 2006
After driving for a few miles, you should also clean your MAF sensor. Some of the oil from the K&N will be blown downstream and will collect on the heated MAF wires, which will goo them up and could cause incorrect airflow readings.
Just spray the MAF wires with MAF sensor cleaner or electronic parts cleaner (NOT carb or TB cleaner!), let dry, and you're good to go.
M
2001 v6 heater hose quick connect question
  • mnky99
  • Sep 24, 2025
SN95 V6 Mustang Tech Sep 26, 2025
mnky99
M
F
Alternator Not Charging
  • Fri Guy
  • Aug 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 31, 2025
AeroCoupe
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
