I just did a clutch job this weekend on my notch
1. I replaced the pilot bearing, because it came iwth the kit. There is a tool for it, but I didn't have one. I packed the hole with grease, and then took a tightly fitting bolt and pounded it in there. What this does is packs the grease and forces the pilot bearing out. Clean the hole and then set the new one up there, and tap it in using a socket of the same size, or a block of wood. Works just fine. Definately get a clutch alignment tool. That is one tool you will want to have. It was 6.95 from
www.50resto.com. Mustangtuning.com has them for like 3.95. They are just plastic, but they are specifically for a Mustang.
2. Just have the flywheel turned. My machine shop charged me 20 dollars, and it came out great.
3. Torque specs. I got these right out of the Ford Motorsport catalog.
Flywheel to crank--75-85 ft lbs.
Pressure plate to flywheel--12-24 ft lbs. DO NOT OVER TORQUE these, because they will break off in the flywheel and you will be pissed off.
4. People say you need to check alignment of the bell housing to the clutch. You only need to do this if you lost your dowel pins that are in the bell housing. If you still have yours...use them and you will be just fine.
I have driven the car all weekend now...and everything is smooth and great. I can't wait for the 450-500 milles of break in are finished, because the clutch feels like it will grab really nice. Good luck man....
