KDW's
01StangGT
Tampa, FL
Been doing some research on new tires for my 01 Stang. I'm currently running the stock rim / tire 245/45/17. The reviews i have read on the KDW-II seems really good. When i went over to www.tirerack.com they dont seem to carry them in the 245/45/17 the ones i need. My car has been lowered with H&R SS springs, Blisten shocks and CC plates. Can anyone recommend a tire and size or a website that carries the KDW-II in the size i need?
I just dont want to spend 900.00 on some tires and not have my car ride / look right.
Thanks for the Info.
Ok so I was in the same boat you were a couple weeks ago. The BFG KDW comes in two different tread styles, traditional and new. The KWD2s are the KDW with the new tread style, and is not available on every tire width/sidewall ratio setup. For the 245/45r17, you will only be able to get the traditional tread, KDW2s are only available for 275/40r17 and 315/35r17 setups i believe. Here is a PDF straight from BFG with all the tire size and tread style configurations http://www.bfgoodrichtires.com/assets/pdf/gforce_ta_kdw.pdf
I personally went with the KDW 255/45r17, traditional tread
I got my Falken Ziex ZE-512s in P245/45ZR-17 size for $90 each and they are rated higher by Consumer Reports magazine than any other all season performance tire including the F1s.
Look through the Summit catalogue for the drag slicks. There some expensive tires.
Good choice on the KDWs, that's what I use and I can't break these things loose unless I try. ...Which I do often, but the point stands. I like the fact that I don't slide around in the summer here in Florida, anymore.
i love mine also , the KDWS tires are A1 :nice:
I'm sure KDWs are great tires and I'll probably try them next but that tread design looks "H" rated. I need to have my "Z" rated "herring bone" cuts in my tires. That gets noticed too. Wasn't even a week after I got my F1s installed that a guy at the gas station said, "Hot tires for a hot car"... I swear...! My girlfriend was there and commented on how often my car gets compliments.
