  • SN95 4.6L Mustang Tech
Kenne Bell and Octane question
  • Thread starter Thread starter JetBrett
  • Start date Start date Feb 19, 2004
JetBrett
384
Sammamish, WA
Feb 19, 2004
  • Feb 19, 2004
For those of you running the Kenne Bell 9psi kit, are you having to use an octane booster or can you run 92 octane gas without problems? The website seems to indicate that you need to use race gas or an octane booster above 6 psi, but all the articles about the supercharger seem to indicate that a step colder plugs plus 92 octane pump gas will be fine. Which is it?
MT1083
1,033
Charlotte, NC
Feb 19, 2004
  • Feb 19, 2004
Mine is not yet completely installed. But KB says in their manual that premium pump gas will be fine. But it also says to always carry around a can of NOS octane boost just in case you get a bad tank of gas. I'm running colder plugs on mine also. You can pm Brightblue00GT and he will let you know. He has had his since august I believe.
00s281sc368
532
Fremont, CA
Feb 19, 2004
  • Feb 19, 2004
9psi runs on 91 pump gas !
Bob H
49
Central Ohio
Feb 20, 2004
  • Feb 20, 2004
Go to the Kenne Bell site and at the very end of the tech section for the 4.6 they have a chart which shows the octane needed for the non intercooled & intercooled Kenne Bell superchargers at various boost levels. I believe it shows 92-94 octane for the intercooled with 9 lb boost.
JetBrett
384
Sammamish, WA
Feb 20, 2004
  • Feb 20, 2004
It what actually led me to post. In the FAQ section they say at 5-6 psi requires 92/93 Octane and that 94 will allow another 1-2 psi of boost. If they are saying in the owners manual that premium or 92 octane is fine for the 9 psi kit, that's good enough for me. It doesn't make sense that they'd put out a "street" 9 psi kit where you had to use race gas, but then again, I didn't want to take anything for granted.
B C
444
Chino, CA
Feb 20, 2004
  • Feb 20, 2004
91 octane @ 9 psi here too.
00s281sc368
532
Fremont, CA
Feb 20, 2004
  • Feb 20, 2004
Yes, 91 octane, that's what they tuned our chip for.
E
el_kid_1
738
Puerto Rico
Feb 20, 2004
  • Feb 20, 2004
KB recommends 91 octane for the 9 psi IC kit. They suggest using 100+ octane gas only when you increase boost or, if you have the switch chip, run on the shoot out mode. The shootout mode will set the spark timing @ 23* and lean the engine a bit, and hence their recommendation. You should also use colder plugs. All these will make your engine less prone to detonation. That way you will enjoy your kit on your stock block for many years to come
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
H
Fuel starvation issues, 91 EFI to carb swap. Car dying after 1-3 gallons used. EFI tank, electric fuel pump, bypass regulator. Dual fed carb
  • hassler
  • Oct 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 12, 2025
nickyb
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Sep 7, 2026
AeroCoupe
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
