Kenne Bell installation - Miscelaneous
Explanations and photos in KB Installation Manual are very clear in general, but there are a few points that i can't find.
I would appreciate if somebody can send me photos, a web site or an answer with more details:
1. Which is the correct way to install the KB chip? (where to put the foam?, the ECU remains open on top, after installation?)
2. Where is the best place to "tee" de vacuum hose to connect Boost-a-Pump
3. Where must i install the "little disc" provided? (metal made, about half an inch diameter)
Thanks in advance!!!
(1) make sure the contacts are down to copper and clean,the top goes back on, not sure what foam your refering too, but if it is not in way of chip,put it back
(2)I tee'd mine into the hose going to bypass
(3) the disc goes under the frps on the fuel rail
