KEY HELP
I have a 2002 Mustang GT I think I have I have right key in it but I am not sure when putting key in and turning on what is alarm light supposed to do Car is not running now because of fuel pump.but wana make sure about security while I am working on it Thanks for any help
In my car (a 98, but also Gen 2 PATs), the wrong key will turn the engine over but it won't start. The "Theft" light on the instrument cluster flashes when this happens as well.
Turn the key to the run position but do NOT crank. Does the theft light go out after a 3 second "prove out"? If so, this means that the PATS key was read and accepted.
Does the theft light continue to flash or on solid? IF so, then the PATS key read failed and the motor will not start.
1996+ Crank with no start check list
Note, the 1999-2004 model year PATS does NOT disable the fuel pump. So a PATS issue will not cause a problem in the fuel pump operation.
