Koni Sale
  • Thread starter Thread starter limp
  • Start date Start date Apr 20, 2022
First Prev 2 of 2
limp
wrap a little cheese around it and its a done
5 Year Member
Oct 4, 2020
5,497
2,918
173
Florida
Apr 21, 2022
#21
  • Apr 21, 2022
  • #21
7991LXnSHO said:
Orange are the softest, like the soft setting on the yellows, is what I read.
I disagree with the statement that the shocks only affect the ride a little bit. Unless you have a ridiculously high spring rate, (for a lowered or track only car), the shocks’ valving will make the difference between feeling every expansion crack and rock or not, and floating or having very little suspension travel over road variations.
Springs do matter in ride quality and handling, but they have to work with the dampers.
Example, on our first band wagon, I had the shocks and struts replaced, and they used the wrong KYB model. It went to riding like a freakin’ lumber wagon until we sold it. The next time, I was specific about which Monroe shocks and struts I wanted, and not only did it get rid of the rear float over big road dips it came with from the factory, it also rode smoother, even fully loaded.
The Oespectra dampers I put on my Grand Marquis restored both the ride and handling to smooth and more controled to cop car and taxi levels. I could have gone with something tighter, but these dampers and springs work well together.
You have to think about the whole package.
KYB's are known for being harsh.... Once was enough, never a KYB buyer again
limp
5 Year Member
Oct 4, 2020
5,497
2,918
173
Florida
Apr 21, 2022
#22
  • Apr 21, 2022
  • #22
7991LXnSHO said:
Ok. You are also thinking about the whole package. If the springs are too strong, and the shocks soft, it will feel every surface imperfection and still bounce over slight dips. Or it will bottom out on the street.
Yes, sway bars are a big part of handling, and less about ride, but the whole package makes a difference.
@limp the yellow ones are adjustable, so they are more expensive. If you are not auto crossing, (running over orange cones in a parking lot? ), not going on the tail of the dragon, not drifting, and Bentley does not like getting jarred, I bet you would not use more than the low setting and may like the OEspectra. If I am off about your cruising expectations and demographics, get the yellow Koni’s and follow Warhorseracing for appropriate advice.
Bentley just digs " bein in the Wind".....
Rdub6
So while I wait to figure out my rear end issues
5 Year Member
Dec 29, 2017
3,957
2,937
153
Long Island, NY
Apr 21, 2022
#23
  • Apr 21, 2022
  • #23
General karthief said:
Nothing about wheels and tires, they also effect ride/handling.
For sure. Bigger wheel, shorter,
stiffer sidewall…….. fillings are getting shaken loose!!
7991LXnSHO
wanna catch the space herp
7,387
2,745
194
Kearney, NE
Apr 21, 2022
#24
  • Apr 21, 2022
  • #24
As a parts pro, that tells me that Koni’s are not going to make you happy either. I’ve not bought the orange ones, but their soft setting should be at least as “controlled” as any KYB set.
Rdub6
5 Year Member
Dec 29, 2017
3,957
2,937
153
Long Island, NY
Apr 21, 2022
#25
  • Apr 21, 2022
  • #25
I have the KYB AGX on all four corners. This was part of a 5 lug/ 4 wheel disc conversion, lowering springs (eibach pro kit) so a lot was changed at the same time. But so far, I’m very happy with the results…..expecting it to be a little harsher than OEM. I have the AGX set at the middle setting, and haven’t played with it, plus or minus.
limp
5 Year Member
Oct 4, 2020
5,497
2,918
173
Florida
Apr 22, 2022
#26
  • Apr 22, 2022
  • #26
Firm and harsh are two separate characteristics to me... Alot of info about KYB online, the shock that is " always priced well"....
First Prev 2 of 2
F
For Sale 03 Redfire Cobra Convertible
  • FastFox5oh
  • Jul 14, 2026
SN95 Mustangs For Sale (1994-04) Jul 14, 2026
FastFox5oh
F
F
Sway Bar Endlinks
  • Fri Guy
  • Jun 30, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 30, 2025
Fri Guy
F
Bilstein shocks
  • cnorman31
  • Dec 21, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 24, 2024
limp
New to me 98 Cobra
  • bird_dog0347
  • Feb 25, 2025
2K
1996 - 2004 SN95 Mustang -General/Talk- Mar 24, 2026
FastDriver
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
