  • SN95 V6 Mustang Tech
lady needs help with current draw
  • Thread starter Thread starter mustangmichelle
  • Start date Start date Jun 12, 2010
M
mustangmichelle
  • Jun 12, 2010
hello, my name is michelle, i have a 94 mustang that has a 4.5amp current draw on the eec circuit when the key is off. i have disconnected all the wires on the alternator, all the fuses for the hood lamps, dome lamps ect. the 20amp fuse for the eec under the hood seems to be where im getting my draw from. when i pull the eec fuse it drops to a few miliamps. it seems like the computer is staying powered on at all times. i even disconnected the ignition switch harness under the column, and the ccrm harness. i dont see how the eec circuit can still be drawing power if the relays are disconnected?
i have most of the diagrams but i was hoping maybe some of you guys might be able to help a lady in distress. im at a loss here, i need my car running so i can get to work! help!
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Jun 14, 2010
  • Jun 14, 2010
4.5 amps is a BIG parasitic draw. It is completely normal for the PCM to draw a few mili-amps all of the time.
How did you measure the current draw? Did you also test pulling the fuses in the I/P fuse panel inside the car?
Has there been any work done to the car? New audio system? Sub amp? After market lights? Alarm system? Navigation system? Anything running from the 12 volt power outlets (cell phone chargers, DVD systems)? Speedcal?
Is the top of the battery clean? Are the battery cables clean and tight?
I suspect that you have not identified the fuse that is actually causing the problem.
If the draw can not be traced to a fuse, then have your alternator tested. Any autoparts store will be happy to test for free.
A
Aeroman
57
  • Jun 14, 2010
Does the engine run ?
D
Possible Parasitic Draw... Follow My Journey
  • daveinfl33777
  • Jan 11, 2025
  • 2 3
3K
SN95 V6 Mustang Tech Apr 4, 2025
dennisc
D
T
2002 V6 3.8L Help Me
  • TheIncompetentMechanic
  • Apr 4, 2026
  • 2 3
1996 - 2004 SN95 Mustang -General/Talk- May 12, 2026
T
A
Resolved 03 GT Parasitic Draw Fuse 26 (PCM)
  • Antrix
  • Mar 22, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 24, 2025
89ripper
N
Complex changes need help
  • nomoremasks
  • Sep 15, 2025
1996 - 2004 SN95 Mustang -General/Talk- Sep 15, 2025
nomoremasks
N
T
Need help 67 hazard flashers not working
  • THS70
  • Jan 21, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jan 29, 2026
