  • 2010 - 2014 Specific Tech
Laguna Seca Boss rear end questions
  • Thread starter Thread starter Shibney
  • Start date Start date Jan 14, 2012
Shibney
  • Jan 14, 2012
I have a 2012 Laguna Seca Boss that has a bent rear end. i was told by someone that the housings where the same as a regular GT. Does anyone know what I would need to do to find this out?
I'm guessing I could just change out the center chunk if that's the case.
This car was hit down the side and I'm going to repair it, but finding one of these rear ends is impossible.
Thanks for your help.
Admin Dude
Jan 4, 1985
43,096
21,280
234
Box behind Walmart
Jan 14, 2012
  • Jan 14, 2012
Do you have pics of the damage?
Shibney
  • Jan 14, 2012
Several. I can fix that part of it, no problem. I just need to know about the rear end. It's the only part I'm not unsure of.
The rear end in it is definitely bent.
Admin Dude
Jan 4, 1985
43,096
21,280
234
Box behind Walmart
Jan 14, 2012
  • Jan 14, 2012
I do not know the cold, hard answer to your question. HP between the GT and Boss are very similar but I'm not sure what (if any) performance enhancements your Laguna Seca got as part of the package. That's why I ask if you have pics of the damage to the axle. If it's just the tube or housing then I'd say that a GT part really makes no difference. If it's hard points and attachment gear, then there are probably differences. So we'd need to know exactly what parts are bent/broke in order to make an educated guess or even try and find part numbers to see which model they applied to.
Shibney
  • Jan 14, 2012
It pushed the wheel back and when it did it broke the tube where it goes into the center chunk. I think everything in my center chunk should be OK. Do you know what is different about a boss rear end? Just a little stronger?
Shibney
  • Jan 14, 2012
Also- I think it's on our lift, i'll try to get some pictures. Thanks so much for your help.
Admin Dude
Jan 4, 1985
43,096
21,280
234
Box behind Walmart
Jan 14, 2012
  • Jan 14, 2012
I don't think that the housing is any different between the two cars. What I think is different is the way that the housings are mounted and how the suspension is is tuned and quality of parts that attach the housing to the rest of the car.
That "chunk" that you refer too. Is it the differential that you're talking about?
Shibney
  • Jan 14, 2012
Yeah, the rear diff.
Svtpilot
944
59
59
Long Island, NY
Jan 14, 2012
  • Jan 14, 2012
I took a quick look at Fordparts,com and they show the same part# for the diff housing on all V8 Mustangs. But to be sure however I take a ride over to the local Ford dealer's parts dept and have them look it up. Same part # same part.
Admin Dude
Jan 4, 1985
43,096
21,280
234
Box behind Walmart
Jan 14, 2012
#10
  • Jan 14, 2012
  • #10
Wut he said. ^
Shibney
#11
  • Jan 14, 2012
  • #11
Cool! Thanks guys. That should save me a little money. I paid way too much for the car, but at least I'll have fun with it.
Admin Dude
Jan 4, 1985
43,096
21,280
234
Box behind Walmart
Jan 14, 2012
#12
  • Jan 14, 2012
  • #12
Well you can always just give it to me and I'll endure the rigors of getting it repaired.
K
KONA12
31
#13
  • Jan 14, 2012
  • #13
Same only difference for the most part maybe sways or controller arms
Rear quarter window regulator
  • BADAZZOMBIE08
  • Mar 29, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Mar 29, 2026
BADAZZOMBIE08
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 14, 2026
joeybuddy96
J
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 15, 2026
FastDriver
Drive Shaft/Rear Diff Issue on 2014 GT
  • DudeStang
  • Jun 16, 2025
2010 - 2014 Specific Tech Jan 21, 2026
gkomo
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
