Larger MAF require a tune?
  • Thread starter Thread starter aNotchAbove
  • Start date Start date Jun 15, 2007
A
aNotchAbove
75
  • Jun 15, 2007
Just wondering if there are any downsides to replacing the stock MAF with a 76mm ProM unit without retuning the air/fuel? The other mods to the car are ported E7's, a TFS street heat intake, and a 70mm throttle body.
vristang
4,933
101
124
Seattle
Jun 15, 2007
  • Jun 15, 2007
As long as the MAF meter is properly installed, and properly calibrated for your ecu and injector size, then you should be just fine without a custom J3 chip.
Sometimes idle problems come up, which can only be improved so much with out getting into the ecu...
But, in theory, your setup should be fine...
jason
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
C
Dyno day! # guesses?
  • clayton seiders
  • Aug 15, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 16, 2025
Scrapla347
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
