Well I wondered if my thermactor plugs would leak when I put on some antiseize on the plugs and put them in the back of my heads...well today I went to check it and see if I could feel any blowing out by the plugs on the back of the heads...so I stuck my hand back there and didn't feel anything...so I stuck my finger over the plug and swear I felt it suck my finger to it when I had it resting against it...is that what it would do if there was a leak...would it suck in air where the old smog pipe went...
Also I have the thermactor plugs in the front of my engine as well...I guess I will need to pull those out to if there really is a leak...
So do I just put silicone on the threads and screw them in and let them dry...
What is an easy way to get those plugs out of the back of heads...hardly any room back there...
if you can tighten them more with the heads on the car, then you could probably get them off with a combination of pliers and whatever kind of head it has.
