Leaking from Dash. HELP
87WhiteStang1
182
Yesterday i was driving and noticed a puddle on the passenger side floor. It looks like its coming from the heater core. right where the drain goes throught the firewall. its like its draining into the car instead of on the other side of the firewall. Its not coolant its just cold water. I thought it was from the AC but it was doing it even with the AC off, with the car running. Any advice would be great. THANKS
That's a very simple one and I'm kind of surprised no one responded. Your AC drain pipe is clogged. Get underneath the car, find it and run a small hose up there to clean it out. It should drain fine after that unless you have something really big in the AC drain pan to which the drain pipe is attached. In that case, use some vacuum, other than your mouth, to suck it out.
Good luck..........
