leaky fuel injectors again.
69restomod
licensed drug dealer!
I recently replaced 6/8 fuel injectors about 2 months ago (they were used injectors) and now the ones I replaced are leaking on the upper portion connecting to the fuel rail same as before now the leaks are from the last 6 injectors and these are the ones I replaced. I also get a fuel smell whenever it marks a 1/4 tank of fuel used from when the tank marks 3/4 full to when I fill up at 1/4 tank of fuel.
I plan on replacing the fuel rails as this is the only item that has not been replaced. But I was reading on the part synopsis that it requires some modifications what does this entail and @ what difficulty level would this accomplished.
The fuel rail is from Steeda for 169.00 and this is only the pair of fuel rails and I believe of Aeromotive has a kit for 440.00 all that is required is to assemble and install. I also plan to replace the injectors in about 2 months. So my stang is parked until this is resolved because I fear a engine fire or something. :(
Thanks for any help.
