  • 2005 - 2009 Specific Tech
Lean% On Brenspeed Tunes?
  • Thread starter Thread starter anticubicle
  • Start date Start date Sep 13, 2007
A
anticubicle
268
  • Sep 13, 2007
Wondering if someone with an 05+ GT and a Brenspeed tune can fill me in on what % Lean (or Rich) the tune is running at. I've got a Predator and can adjust how lean (or rich) the car is to run via the fuel table and am wondering what those Brenspeed tunes are running @ w/ the Xcal.
Any info would be appreciated.
Thanks!
M
maxima
146
  • Sep 13, 2007
id like to know to
DarkFireGT
Playing with my wife's really makes me want one.
692
10
89
East Moline, IL
Sep 14, 2007
  • Sep 14, 2007
Well, every car is going to be different. A good tune for an NA motor should be around 13:1. The only way to tell is hook it up to a wideband. They try to hit 13:1 when they give you the tune, but every car will react differently to mods and tunes, so a wideband on the dyno is your best bet to check out the AFR.
AlloyGT
64
Colorado
Sep 14, 2007
  • Sep 14, 2007
Thanks!
I believe that with both the Predator and the XCAL, the Fuel % adjustment which you speak of refers to changing the tune you have loaded on the predator by XX%. Unless you know what you're doing, don't do this, or you may become the proud owner of a Vapor Metallic paperweight.
M
mongoose101
22
  • Sep 15, 2007
Thanks!
You and a million others. That is why you cannot read the tune. Spend the bucks for your own SCT
A
anticubicle
268
  • Sep 16, 2007
It's called helping out. I'm not asking for all the tune parameters. I'm asking how lean the cars with the SCT Brenspeed tunes are running.
I can modify my Predator no problem, hell I have it dyno tuned by DiabloSport themselves. I'm asking for my own reference. I've got my Predator's fuel base set to 3% lean on both RPM ranges at the moment.
Was just curious so no need for rude comment
onebad95
Sherriff of Bling King County
Jul 22, 2002
1,237
At the end of the track waiting for you !!
Sep 16, 2007
  • Sep 16, 2007
Actually, that is a good question. I just uploaded my program I got with the tuner and never looked at the %. I will see if I can get that information. It would be nice to see what the results are with all these different guys tuning all our car's. Again, good question anti.
DarkFireGT
692
10
89
East Moline, IL
Sep 16, 2007
  • Sep 16, 2007
The percentage should be 0, that way you can tweak it up or down 3%. But again, you'd have to run a wideband while dynoing to figure out how much you should change it. You don't want to blindly change it unless you're throwing lean or rich codes.
Hoodlum
Augusta, GA
Sep 19, 2007
  • Sep 19, 2007
Just got back from a dyno day on saturday and I have a brenspeed 93 tune and a jlt II intake. The richest I hit was 10.0 and I hit a couple of times 10.5 and the tuner said that not even SCT makes their tunes that rich.
Check out video and pictures of the dyno sheets.
http://videos.streetfire.net/uploaded/Hoodlum.htm
StonePony
218
#10
  • Sep 19, 2007
  • #10
Brent has my A/F between 11.5 and 11.8 while running 11 PSI
A
anticubicle
268
#11
  • Sep 19, 2007
  • #11
I see....I'm currently running my tune @ 4% lean. Going back into DiabloSport soon to get some more Dyno Tuning done. Will letcha guys know what turns up.
K
kkdoughboy
212
Pennsylvania
Sep 21, 2007
#12
  • Sep 21, 2007
  • #12
Anti, What are you mods that your running it 4p lean?
A
anticubicle
268
#13
  • Sep 22, 2007
  • #13
See my sig.
DarkFireGT
692
10
89
East Moline, IL
Sep 22, 2007
#14
  • Sep 22, 2007
  • #14
You really shouldn't be messing with the AFR without seeing your AFR on a dyno with wideband monitoring. 4% is quite a bit of change. If your tune was dead on 13:1, that could put you in dangerous territory, and you could be losing quite a bit of power. You can't blindly change your AFR unless you're getting CEL's indicating it's needed. If you were getting a CEL saying you were running rich, I could see leaning it out until you can get to the dyno, but otherwise there's no reason and you really could be harming your engine.
K
kkdoughboy
212
Pennsylvania
Sep 24, 2007
#15
  • Sep 24, 2007
  • #15
I agree with darkfire. I wouldnt run at 4 percent lean. Your mods really dont necessitate a lean like that. I'm surprised that your happy with how the cars running. Just my opinion.
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
Tips for WUE and ASE tuning
  • Mustang5L5
  • Oct 9, 2025
  • Digital Self-tuning Forum
Digital Self-tuning Forum Oct 10, 2025
gkomo
Tunerstudio help / services
  • Kabuki_notch
  • Apr 26, 2026
Digital Self-tuning Forum May 2, 2026
Mustang5L5
VE Table Not Dialed? Send Me Your Datalog.
  • X-cam34
  • Feb 8, 2026
  • 2 3
2K
Digital Self-tuning Forum May 1, 2026
X-cam34
Free VE Table Corrections — Drop Your MSQ and a Datalog, I'll Do the Rest
  • X-cam34
  • Apr 12, 2026
  • 2 3
2K
Digital Self-tuning Forum Aug 26, 2026
X-cam34
