Lets talk about Sc-trims
  • Thread starter Thread starter 1SickFox
  • Start date Start date Jan 16, 2009
1SickFox
  • Jan 16, 2009
Who is happy with their Sc-trim? Would you change anything? How much hp did you pick up? Did you put a aluminum discharge tube and a AFM powerpipe on it? Were you happy with 5-6lbs of boost? Just tell me about your expierence! Thanks
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Jan 17, 2009
  • Jan 17, 2009
Don't have one on a 5.0L, but my 96 Cobra went from 289RWHP to 408RWHP.
I had a Procharger 11psi on a 95GT with HCI as well. Don't know the HP, but it ran 113.5MPH in the quarter mile. Most stock 94-95 GT's only turn 94-98MPH. I only had 3.08 gears too. 3.73's should have put that car at 116-117MPH.
Go 8-10psi. 5-6 won't do a whole lot.
MAC'n89Blckstng
1,012
NJ
Jan 17, 2009
  • Jan 17, 2009
I've seen the AFM powerpipes put some serious numbers down to the wheels. I would also run 8-10 pounds as a stock block would hold up fine with that. 5-6 may not be worth it.
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Jan 17, 2009
  • Jan 17, 2009
5-6 psi is a huge difference over N/A.
on my old combo with thumper heads and b-cam. best i mangaged N/A was 13.3 103
added an SCtrim with a UPR boostmaster pipe, with 6 psi i manged 12.1@113.
made a big difference.
and NO you wont be happy with 5-6 psi, its a good difference but its so easy to swap pullies and make more boost. i added a crank pulley and made around 9 psi.
i picked up a few MPH to 115 but never got a faster E/T due to traction issues. i did managed the same 12.1 but with a slow 60'.
i ran the combo untuned, with stock injectors and an FMU and ended up blowing a HG.
over that winter i upgraded to some TFS TW heads and an f-cam. got it running again and this time i used a tweecer and 42lb injectors. and tuned the car properly. boost dropped to 7 psi with the head and cam change, but the car quite a bit faster. later on i threw a smaller blower pulley on and make 12-13 psi. the car ran REALLY good then.
never got back to the track but i would have guessed it would have been in the 11.5 range at 120ish MPH maybe quicker. it was a quite a huge difference with the better heads and cam and more boost.
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
Progress Thread Progress Thread- From6to8's 1994 Cobra Supercharger install
  • from6to8
  • Sep 25, 2025
  • 20 21 22
10K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jan 11, 2026
02_2v_Curtis
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
