- Jack the front wheels in the air supporting them by the lower control arms with jack stands as close to the lower ball joints as possible to unload the suspension.
- Have your friend grab the fronts of each front tire, one at a time, and shake them from left to right. While he is doing this, squeeze the bellows boots on the rack-and-pinion and check for play on your inner tie rods.
- Crawl under the car and take some pics of your lower control arm bushings. If they are blatantly dry-rotted or partly missing, you need new ones (no pic necessary).
- Grab your front sway bar and see if you can move it or slide it side to side.
- Try to squeeze your outer tie rods, in the palm of your hand, and see if they move when squeezed by the pressure of your hand.
- Check for dry rot on the rack-and-pinion bushings and see if you can move the rack-and-pinion by pulling or pushing on it.
All of the above can cause sloppy steering or a loose suspension. If you find any play, replace all the components that are causing the problem.
