Hi all, I've been reading up on lifters, solid, hyd, cam profiles for both, with and without rollers.
Now it got me thinking about people recommending higher ratio rockers - now my theory is this:
Say you want .5 lift on your valve. If you use a 1.5 ratio rocker, the lifter and pushrod have to move further, in the same amount of time, thus also faster. This is more inertia. If you up the ratio of the rocker, and want to maintain the lift, you'll have to use a smaller cam profile which moves the lifter and pushrod less - less inertia.
Now for higher rpms in a hydraulic roller setup is it better to have less lifter / pushrod movement and more ratio which would impart more pressure on the plunger but be easier to control for the spring (as it has more leverage, and the lifter / pushrod is moving slower)
OR
To have the lifter and pushrod moving faster with less pressure on the plunger but giving the spring less leverage to control that part of the valvetrain while it moves faster?
My guess is the first one as the lifter and pushrod would make up a very big majority of the valvetrain mass, so controlling it is a major factor.
Then again, the extra spring pressure would have a greater impact on the plunger in that there is more pressure to push the plunger down, and the amount that the plunger moves is a bigger proportion of the total cam lift over what it would be with the lesser ratio rockers.
Hmm so what say all ye tech heads out there?
EDIT: I would definitely pick the first one IF the plunger spring was replaced with one with a greater RATE - same (almost) seat / preload pressure but stronger rate to combat the extra leverage against it.
Is it possible to get better springs for the plunger??
OR
You can tell it's getting to be winter time down under.........
I asked this question to a friend that builds race motors. He prefers the higher ratio rocker route. I thought a larger cam profile with less ratio would have been better. I think to find which is better you'd have to build a test mule motor and try each on a dyno. Otherwise the difference probably would never register on the seat-of-the-pants meter.
