Liquid to Air Intercooler
  • Thread starter Thread starter bditty50
  • Start date Start date Jul 31, 2007
bditty50
170
Tampa, Florida
Jul 31, 2007
  • Jul 31, 2007
Has anyone ever installed a liquid to air intercooler on a lx coupe 5.0? If you've seen it where would you put it seeing how big they are(besides the passenger seat)? Also, has anyone used the dez racing intake liquid to air?
bditty50
170
Tampa, Florida
Jul 31, 2007
  • Jul 31, 2007
Could you use one of these Vortech intakes with a turbo car?
http://www.vortechsuperchargers.com/product.php?p=20&cat_key=3
Rick 91GT
Mustang Master
95
99
PA
Jul 31, 2007
  • Jul 31, 2007
You can get dash mount A/W intercoolers, then run your pump and lines in the trunk to a seperate cell.
The Vortech Igloo will work but I would suggest you go with a seperate A/W which will be more efficent.
Check out www.chiseledperformance.net Robert makes some very nice pieces, you can also mount your tranny cooler in the bottom to help keep that cool or run it in a seperate small tank. (that is what I have for my own car)
bditty50
170
Tampa, Florida
Aug 1, 2007
  • Aug 1, 2007
Could you show me some pics of the underdash unit? I want to stay factory like and not have alot of heat under the dash. Where else can you mount a air to water so its out of the way and I dont have to cut anything? I like the intake style setups better just because it centered in the car for good weight transfer.
Rick 91GT
Mustang Master
95
99
PA
Aug 2, 2007
  • Aug 2, 2007
you will loose your heater core, etc....
bditty50
170
Tampa, Florida
Aug 2, 2007
  • Aug 2, 2007
Well I'm not interested in that. I'd like a front mount that can fit under an lx bumper or a intake style one. Does anybody do anything like that?
Rick 91GT
Mustang Master
95
99
PA
Aug 2, 2007
  • Aug 2, 2007
The 2 pics I showed go up under the dash, you do not see them at all, then you run a seprate water/ice cell in the trunk and run 2 rubber lines back to it. I have seen a/w coolers up front but it adds a lot of weight to the front and can cause some space issues.
If this is a race car I would do the cooler mounted where the passenger feet or behind the pass seat or the under dash. If this is a street car just go A/A and save your self a lot of money and hassles.
What is your intentions with the car?
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
Engine Bleeding air in the heater core
  • keel
  • Apr 2, 2026
Fox 5.0 Mustang Tech Apr 23, 2026
limp
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
  • Mindseye007
  • Aug 16, 2026
Mindseye007
N
Need stainless carb heat shield
  • newmex999
  • Aug 29, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 13, 2026
Mcmahst
