1979-1986 Fox Body Mustang: 5.0 Resto Window Run Channel Trim - Overview & Install
Replace your 1979-1986 Fox Body Mustang window run channel trim with these factory-style replacements from 5.0 Resto. This trim surrounds the window frame of your door and is needed to properly locate the run channel weatherstrip. Typically, these are mishandled during removal, which results in them becoming bent, dinged, and damaged. 5.0 Resto's trim has the correct channel that allows it to slide onto the window frame and stay securely in place. Your window run channel weatherstrip then slides next to the trim, ensuring your windows are sealed properly.
Manufactured in the factory two-piece design, this trim is a direct replacement for your original. Each aluminum section is precision-built to factory specs for a perfect fit and finish. The long, horizontal trim has the correct end cap by the mirror and the L-bracket to secure it to the vertical trim. That vertical trim has the correct indention at the bottom, allowing the door belt to overlap for a finished look. Trim black paint is applied to each trim to ensure this window run channel trim kit is the perfect restoration item for your Fox Body Mustang. This trim can also be prepped and painted using the LMR Dark Grey exterior trim paint (linked below).
*Product Links*
79-86 Window Run Channel Trim:
https://lmr.parts/LRS-21596B-TR
79-93 Window Run Channel Weatherstrip:
https://lmr.parts/LRS-21596PR
79-86 Outer Door Belt Molding/Weatherstrip:
https://lmr.parts/LRS-20544PR
LMR Exterior Paint:
https://lmr.parts/exterior_paint
*Watch*
87-93 Window Run Channel Trim:
Run Channel Weatherstrip Install:
81-86 Door Panel Removal:
*Torque Specs*
Window Run Channel Screw - Hand Tight
*Chapters*
00:00 - Run channel trim overview.
03:14 - How to remove the run channel trim.
07:21 - How to install the run channel trim.
11:01 - Final thoughts & outro.
*Social*
YouTube:
https://www.youtube.com/user/latemodelrestoration
Facebook:
http://www.facebook.com/latemodelresto
Instagram:
http://instagram.com/latemodelresto
TikTok:
https://www.tiktok.com/@latemodelresto
#lmr #foxbody #mustang
Use of this video is subject to the terms as set forth in our LMR Install Video Disclaimer |
https://lmr.com/page/lmr-install-video-disclaimer
