LMR Youtube Channel
2024-2025 S650 Mustang: How To Remove Spoiler Module
In this video, Landan explains the process of removing the spoiler module from a 2024-2025 S650 Mustang.
*Product Links*
Shop S650 Spoilers: https://lmr.com/products/2024-mustang-rear-spoilers
*Watch*
RTR Spoiler Install:
*Tool List*
Microfiber Towels
Waterless Wash Product
Isopropyl Alcohol (Prep Spray)
Adhesive Remover
Fishing Line (to separate the double-sided tape)
1/4" Socket Wrench
1/4" Socket Set
1/4" Extensions
*Torque Specs*
Spoiler Module Retaining Nuts: 49 lb-in
Spoiler Module Retaining Screws: 22 lb-in
Backup Camera Bracket Screws: Hand Tight
*Chapters*
00:00 - Video intro & explanation.
00:52 - Open the trunk & disconnect the negative battery cable.
01:06 - Remove the trunk liner.
01:42 - Loosen & remove the spoiler module hardware.
02:30 - Remove the spoiler module.
03:01 - Clean the trunk & remove the tape residue.
03:33 - Final thoughts & outro.
*Social*
YouTube: https://www.youtube.com/user/latemodelrestoration
Facebook: http://www.facebook.com/latemodelresto
Instagram: http://instagram.com/latemodelresto
TikTok: https://www.tiktok.com/@latemodelresto
#lmr #s650mustang #howto
Use of this video is subject to the terms as set forth in our LMR Install Video Disclaimer | https://lmr.com/page/lmr-install-video-disclaimer
If you’re heading to Mustang Week be sure to stop by Retro Meet VIII! ️ #latemodelresto #shorts
Which transmission is your favorite for the New Edge Mustang? #latemodelresto #shorts
OBS Ford Bronco & F-150 Lightning: SVE Factory-style Steering Wheel - Review & How To Install
Replace your faded, ripped, or worn-out 1994-1996 Ford Bronco or 1994-1995 F-150 Lightning steering wheel with this perforated leather steering wheel from SVE. One of the most overlooked parts of your OBS Truck that sees more use than any other part of the truck is your steering wheel. Daily driving takes its toll on your steering wheel. You'll see the grain on the leather turn smooth, shiny, and eventually crack. Mirroring the design of the Lightning steering wheels, this SVE leather steering wheel for your 1994-1996 Bronco is thicker and more comfortable than the factory! This SVE steering wheel has a factory-inspired design with perforated leather throughout and a black finish to match your interior.
Starting with a new aluminum frame, this SVE steering wheel has the four spokes around the airbag molded in an OE-style textured urethane. After the molding process, the steering wheel is wrapped with perforated black leather and stitched with black black thread for a clean appearance that looks like it could have rolled off the assembly line. SVE made the wheel slightly thicker than stock to give you a better grip and make it feel nicer in your hand.
*Product Links*
94-96 OBS Bronco Steering Wheel: https://lmr.parts/FTP-3600B
94-95 F-150 Lightning Steering Wheel: https://lmr.parts/LTP-3600B
Bronco Steering Wheel Bolt:
Lightning Steering Wheel Bolt:
Steering Wheel Puller: https://lmr.parts/LRS-2380050
*Watch*
OBS Truck Door Panel Repair:
OBS Truck Door Panel Removal:
*Tool List*
Microfiber Towels
Dedicated Automotive Interior Cleaner
Dedicated Automotive Interior Conditioner
Interior Brush
Phillips Head Screwdriver
Small Flathead Screwdriver
3/8" Torque Wrench
3/8" Extensions
3/8" Socket Set
1/2" Socket Wrench
1/2" Extensions
1/2" Socket Set
*Torque Specs*
Phillips Head Screws: Hand Tight
Steering Wheel to Steering Shaft Bolt: 23-33 ft-lbs
*Chapters*
00:00 - Video intro & back story.
00:55 - SVE steering wheel review.
02:19 - Other parts you may need.
03:05 - Remove the airbag.
03:28 - Remove the steering wheel.
04:15 - Remove the factory parts.
04:41 - Clean up the components.
05:17 - Transfer the factory parts to the new steering wheel.
05:45 - Install the SVE steering wheel.
06:33 - Final thoughts & outro.
*Social*
#lmr #sve #steeringwheel
Gen 1/2 Lightning & OBS Bronco Factory Style Steering Wheels are here! #latemodelresto #shorts
1999-2004 Ford F-150 SVT Lightning: SVE 03-04 Style Steering Wheel - Review & How To Install
Replace your faded, ripped, or worn-out 1999-2004 F-150 SVT Lightning steering wheel with this 03-04 style steering wheel! One of the most overlooked parts of your Lightning that sees more use than any other part of the truck is your steering wheel. Daily driving takes its toll on your steering wheel. You'll see the grain on the leather turn smooth, shiny, and eventually crack. Mirroring the design of the newer 2003-04 Gen 2 Lightnings, this SVE leather steering wheel for the 1999-2004 Lightning is thicker and more comfortable than the factory! This SVE steering wheel has a factory-inspired design with perforated leather throughout and a black finish to match your interior.
Starting with a new aluminum frame, this SVE steering wheel has the four spokes around the airbag molded in an OE-style textured material. After the molding process, the steering wheel is wrapped with thick, perforated black leather and stitched with black thread for a clean appearance that looks like it could have rolled off the assembly line. SVE made the wheel slightly thicker than stock to give you a better grip and make it feel nicer in your hand.
*Product Links*
99-04 Lightning Factory-style Steering Wheel: https://lmr.parts/LTP-3600D
97-04 F-150 Airbag Retaining Bolt Covers: https://lmr.parts/LTP-43518C
99-04 Lightning Steering Wheel Bolt: https://lmr.parts/N807493S100
99-04 Lightning Ford Cruise Control Switch Assembly: https://lmr.parts/FTP-9888C
99-04 Lightning Dorman Cruise Control Switch Assembly: https://lmr.parts/LTP-901399
*Watch*
99-04 Lightning Cruise Control Switch Install:
*Tool List*
Microfiber Towels
Interior Brush
2-Jaw Puller
T-30 Torx Socket
T-50 Torx Socket
3/8" Torque Wrench
3/8" Extensions
3/8" Socket Set
1/2" Socket Wrench
1/2" Extensions
1/2" Socket Set
*Torque Specs*
Steering Wheel to Steering Shaft Bolt: 28 ft-lbs
Airbag Retaining Bolts: Hand Tight (89 in-lbs)
*Chapters*
00:45 - SVE steering wheel review.
02:22 - Other parts you may need.
03:26 - Fitment notes.
04:01 - Remove the airbag.
04:31 - Remove the steering wheel.
05:21 - Remove the factory parts.
06:27 - Cut threads in the new steering wheel.
07:15 - Clean & condition the components.
07:15 - Transfer the factory parts to the new steering wheel.
08:16 - Install the SVE steering wheel.
09:08 - Final thoughts & outro.
*Social*
1990 Fox Body Mustang Saleen Convertible Dyno
View: https://www.youtube.com/watch?v=2VHd-9-hUIs
*Product Links*
Shop Fox Body Mustang Parts: https://lmr.com/1979-93-Mustang
*Watch*
LMR's Dyno Playlist:
View: https://www.youtube.com/playlist?list=PLMti2eKQ3th_SMVaWhDt8PIAuuwAZBL0I
*Relative Dyno Information*
- Temperature: 89 degrees
- Humidity: 56%
- Year: 1990
- Mileage:
- 5.0L Small Block Ford Engine
- Ford Performance E303 Camshaft
- Fenderwell Cold Air Kit
- 75mm Pro-M Mass Air Meter
- 3.55 Rear Gear
- Equal Length Shorty Headers
- High-flow Catalytic Converters
*Chapters*
Intro & Vehicle Specs - 0:00
Dyno Pull - 00:45
Dyno Results - 01:02
*Social*
#lmr #foxbody #dyno
2024-2025 S650 Mustang: RTR Upper, Lower, & Corner Grille - Review & Install
View: https://www.youtube.com/watch?v=soEChSLPZ6Y
In this video, Landan explains the installation procedures and takes a closer look at the RTR upper grille, lower grille, and corner grilles for the S650 Mustang.
*Product Links*
RTR Upper Grille: https://lmr.parts/RTR-11011001199
RTR Lower Grille: https://lmr.parts/RTR-11011000212
RTR Corner Grilles: https://lmr.parts/RTR-11011000312
*Watch*
How To Remove Front Bumper:
View: https://youtu.be/4d9FksZZ1eo
How To Remove S650 Upper, Lower, & Corner Grilles:
View: https://youtu.be/GckXhPXFhvg
*Tool List*
Microfiber Towels
Plastic-safe All-purpose Cleaner
Zip Ties
Welding Rod (Or similar fishing tool)
Tape
Needle Nose Pliers
Small Round File
Panel Removal Tool Set
Flush Cut Pliers
1/4" Socket Wrench
1/4" Socket Set
1/4" Extensions
*Torque Specs*
*Chapters*
00:00 - Video intro & upper grille overview.
01:45 - Lower grille overview.
02:04 - Corner grille overview.
02:43 - Other videos of interest & misc. information.
03:18 - Upper grille install.
06:58 - Lower grille install.
08:06 - Corner grille install.
09:10 - Wiring the upper grille lights.
11:36 - Test for operation.
12:07 - Final thoughts & outro.
*Social*
