LMR Youtube Channel
1979-1984 Fox Body Mustang Body Side Molding & Pin Stripping - Full Install Process
View: https://www.youtube.com/watch?v=OaDxwTruMWE
In this video, Landan explains the process of removing and installing the body side moldings on a 1979-1984 Fox Body Mustang. The icing on the cake is laying the pin stripe in the molding.
*Product Links*
10-piece Kit: https://lmr.com/item/LRS-160MK/mustang-master-body-side-molding-kit-79-84
Pin Stripes: https://lmr.com/products/79-93-Mustang-Body-Side-Moldings-Kits#16709
Exterior Paint & Adhesion Promoter: https://lmr.com/products/79-93-Mustang-exterior-paint
Eraser Wheel: https://lmr.com/item/LRS-400E-KIT/adhesive-removal-tool
Adhesive Remover: https://lmr.com/item/AT-13032/Quick-N-Easy-Adhesive-Remover-32Oz-Spray-Bottle
3M Adhesion Promoter: https://lmr.com/item/3M-06396K/3M-Adhesion-Promoter-Kit-for-Double-Sided-Tape
*Watch*
1979 Cobra Mini Resto:
View: https://youtu.be/SIFQZPYGU6E
1979 Cobra Dyno:
View: https://youtu.be/bXI9_ITuZws
*Vehicle Fitment*
Chassis: Fox Body Mustang
Year Range: 1979, 1980, 1981, 1982, 1983, 1984
*Tool List*
Microfiber Towels
Heat Gun
Fishing Line
Automotive Painter's Plastic
Automotive Painter's Tape
Adhesive Remover
Prep Spray (Isopropyl Alcohol)
Eraser Wheel
3M Adhesion Promoter (6 total)
Pin Stripe
*Chapters*
00:00 - Kit overview & things you need know.
05:35 - Removing the existing moldings.
06:25 - Prep & the body side moldings.
07:33 - Install the moldings.
09:10 - Laying the pin stripe.
13:23 - Final thoughts & outro.
*Social*
YouTube: https://www.youtube.com/user/latemodelrestoration
Facebook: http://www.facebook.com/latemodelresto
Instagram: http://instagram.com/latemodelresto
TikTok: https://www.tiktok.com/@latemodelresto
#lmr #foxbody #carrestoration
Use of this video is subject to the terms as set forth in our LMR Install Video Disclaimer | https://lmr.com/page/lmr-install-video-disclaimer
Are Gen 3 Coyote Mustangs the best? | 2020 Mustang GT Performance Pack 1 Dyno
View: https://www.youtube.com/watch?v=kK3GO6ZxS68
In this video, the LMR teams dynos Mike Nichols' 2020 Performance Pack 1 Mustang GT. It hosts a few bolt-ons, but is currently setup for high performance driving events (HPDE).
*Product Links*
SVE DHP1 Wheels: https://lmr.com/products/mustang-sve-dhp1-wheels-15-23
S550 Mustang Resonator Deletes: https://lmr.com/products/2015-Mustang-Mid-Pipes
S550 Axle Back Exhaust Kits: https://lmr.com/products/2015-Mustang-Axleback-Exhaust
*Relative Dyno Information*
Stock Gen 3 5.0L Coyote Engine
Stock Calibration
Stock MT82 6-speed Transmission (4th gear pull which is 1:1)
3.73 Rear Gears
93 Octane Fuel
Resonator Delete X-pipe
Mach 1 Axle Back
19" SVE DHP1 Forged Wheels
*Watch*
View: https://youtu.be/EEIsuaG_hl8
*Chapters*
00:00 - Intro, video explanation, & vehicle specs.
01:13 - Dyno run.
01:41 - Results.
02:25 - Final thoughts & outro.
*Social*
#lmr #s550mustang #mustangdyno
Increased Stopping Power For Your Fox Body Mustang | Hydroboost Conversion Kits - How To Install
View: https://www.youtube.com/watch?v=5P_iyWbYHVo
Stopping power is important. The hydroboost conversion has always been the top dog of power brake assist setups when it comes to a Fox Body Mustang. Now, you can finally convert your Fox Mustang the easy way; with a complete kit from SVE. We have finally taken the headache out of the hydroboost conversion by building a few different kits to cater to different scenarios. Click the link below to shop the hydroboost conversion kits and parts.
*Product Links*
Hydroboost Conversion Kits & Parts: https://lmr.com/products/79-93-Mustang-Hydroboost-Conversion
*Watch*
Fox Body Rag Joint Replacement:
View: https://youtu.be/Zericm8ZRfo
Fox Body Steering Rack Removal:
View: https://youtu.be/TVcwUpRRsfM
Fox Body Steering Rack Install:
View: https://youtu.be/v0RYGVa7Fqw
How To Install Power Steering Pump Pulley:
View: https://youtu.be/s6OJvpwloB0
How To Flush/Bleed Power Steering System:
View: https://youtu.be/vL2hbJ-wfo0
How To Bleed Brakes:
View: https://youtu.be/B0OEoj-lkkM
*Vehicle Fitment*
Year Range: 1979, 1980, 1981, 1982, 1983, 1984, 1985, 1986, 1987, 1988, 1989, 1990, 1991, 1992, 1993
*Chapters*
00:00 - What is a hydroboost & hydroboost conversion kit components.
10:38 - Removing the pedal assembly & other components.
15:07 - Modify the firewall.
16:33 - Adjust the brake booster pushrod & install the gasket.
19:36 - Install the hydroboost unit.
21:41 - Prepare the pedal assembly & install the pedal arm.
25:27 - Install the pedal assembly.
26:53 - Install the master cylinder & adapter lines.
28:31 - Install the power steering pump & fittings.
33:39 - Install the supply & return hoses.
35:18 - Finish out the rest of the install.
35:42 - Final thoughts & outro.
*Social*
#lmr #foxbody #fordmustang
2024-2025 S650 Mustang: Ford "Air Design" Gloss Black Deck Lid Trim Panel - How To Install
View: https://www.youtube.com/watch?v=Xxh3FjDyhYs
*Product Links*
Gloss Black Deck Lid Panel: https://lmr.parts/LRS-99425A
*Vehicle Fitment*
Chassis: S650 Mustang
Year Range: 2024, 2025
*Social*
#lmr #s650mustang #fordmustang
The BEST Wheel for the OBS Ford Bronco! | SVE Factory Style 10-Hole Wheel
View: https://www.youtube.com/watch?v=aEDQGqm6zyQ
Recapture the truly classic OBS Truck styling with SVE's polished 15x7.5" Factory Style 10-Hole wheel kit on your 1992-1996 Bronco. Every detail of this SVE wheel was carefully engineered to fit your OBS Truck perfectly. With proper backspacing, offset, width, and diameter, it offers period-correct styling and a timeless appearance. Sized at 15x7.5" with a -3 mm offset, 4.125" backspace, and a 5x5.5" (5x139.7mm) bolt pattern. The wheel combines lightweight with proven durability, thanks to its low-pressure casting, coming in at just 15lbs. Each wheel features a polished face and lip, the signature 10-hole pattern, and compatibility with factory-style center caps. Preinstalled anchors ensure a secure fit, avoiding the brittle issues of the old plastic anchors. To top it off, SVE finishes the wheel with a durable clearcoat and backs it with an industry-leading warranty for total confidence. This 10-Hole style wheel is also going to fit other OBS Ford's with the 5x5.5" bolt pattern.
*Product Links*
OBS Bronco Wheels: https://lmr.com/products/1992-1996-ford-bronco-wheels
OBS Bronco "LMR Spec" Lift Kit: https://lmr.parts/FTP-20024
*Watch*
View: https://youtu.be/E772E_8z9Bk
View: https://youtu.be/Mp6_AW5Ftrk
*Vehicle Fitment*
Chassis: Ford OBS Bronco
Year Range: 1992, 1993, 1994, 1995, 1996
*Chapters*
00:00 - Video intro & history of the wheel.
01:22 - SVE factory style 10-hole wheel overview & specs.
02:57 - Center caps & other parts to consider.
03:19 - Purchasing options & "LMR Spec" lift kit.
04:10 - Final thoughts & outro.
*Social*
#lmr #fordbronco #svewheels
