- May 8, 2003
- 150
- 1
- 18
I had a caliper lock up on my 96 mystic cobra (driver side rear).
The disc went white hot, and warped, the caliper cooked.
I didn't think the other caliper was affected.
The brake pedal went rock hard and I think somehow the parking brake got stuck, but I've never see the car do anything like this.
The dealer wants me to replace both calipers and rotors, however he won't
warranty the parts or work if I don't buy the parts from him at his markup.
He says that even oem boxed products would be considered "Aftermarket".
So do I spend $800 and have the new oem calipers and oem rotors go on with the upside being the one year warranty on all work.
Or
Take the $800 and have a local guy do the work with no certain guarantees on the work, but with the same money be able to get a 4 piston caliper willwood set put on both sides with cross cut / drilled rotors.
That or save about $250 by getting the oem parts myself off the internet.
My pal says I should have the dealer do it because the heat might have cooked the bearings, but I don't know about those. He also says that the parking brake install for the rear calipers is tricky and another reason to have th dealer do itl
Opinions?
Or
Opinions?
too this day i wonder if it needed headgaskets...
) then too replace one side and have you come back in a month complaining about the brakes...
