SN95 Looking at maybe my first pony car this afternoon
danhardman
texas
As the title says I'm looking at purchasing my first ever pony. Today I'm going to look at a 94 GT convertible. Are there any tell tell signs I should look out for? The primary purpose of this car is a fuel efficient "more" option for my daughter to go to collage and work for a while then something for my son to build once we get her something a little more practical. Which brings on my next question what power adders are a NOGO without having to go to a programmable chip I plan on learning how to tune but not right off the bat.
If the primary purpose is fuel efficiency, i'd pick something else.
A 96-96 GT with a PI swap would return better fuel economy and still be a fun ~300HP ride
Couple things to look for.
*With the car running, watch for wobble in the crank balancer. These are rubber and if the rubber is coming out of the back, it's wiped.
*Open the trunk, under the rear glass there is black molding, lift that up and look for rust. The metal is very thin under that glass, water likes to live there.
*Rear main seal is probably leaking if someone didn't have it replaced after a clutch change.
*Air bag light is on not to be worried, clock spring is the culprit. Have to pull the wheel to get to it though.
If I think of more I'll come back an edit.
When I say “more Efficient option” I’m referring to not having her drive my 79 F350 with a big block. However I did look at the car and there are a couple minor issues but overall I think I’m going to be ok. It is a one owner unmolested car with 160k on it. It will work for a few months while my daughter saves some money. And her commute is only 15 miles so it will work. The 15-17 mpg this car gets will be way better than the 7 my 79 gets.
My 5.0 actually gets pretty good fuel economy when I’m cruising highway. Last time I took a trip I averaged around 21mpg and that’s with 4.10s. It’s not as good in the city since I tend to lay on the skinny.
I owned a 95 GT ragtop for several years without a problem(180K when I sold it), it is a quantum leap over the pervious Fox Verts in terms of rigidity and noise levels. Plenty of them made so parts are no problem. Automatic I am guessing.
Reactions: Mustang5L5
Welcome to Stangnet... :spot:
Not all of us know how to fix everything, but some of us know how to fix some things with excellence!
Places to check out here on Stangnet:
http://www.stangnet.com/mustang-forums/threads/technical-thread-how-to-index.808661/ How to do it tips for some of the most common problems and upgrades for 5.0 Fox body Mustangs.
http://www.stangnet.com/mustang-forums/threads/the-official-progress-threads-thread.761371/ the collection of build/progress threads from Stangnet members. You get to find ideas and clues to what works well and what doesn’t.
http://www.stangnet.com/mustang-forums/resources/ Has tech tips for common problems on Mustangs.
If you are in California or some other area with strict emissions laws and buy a car, part of the deal should be that the owner takes the car and has it emissions tested. If it passes, you buy the car and pay for the emissions test cost, if any. If it does not pass, walk away from the deal. For a mechanically inexperienced owner, emissions related problems can be difficult and expensive to fix. Avoid any car that was originally EFI and has been converted to carb like the plague. That's often a clue to the fact the previous owner had problems and the resulting hack job has MORE problems.
Keep in mind that areas with strict emissions laws may make the go faster goals more difficult to reach. Some parts are OK to replace with aftermarket parts and others aren't. Check carefully before you get out your wallet and buy something you can't use in the area where you live.
If you want to do the fix up & power up thing, make sure that you have some other form of reliable daily driver. That way the stang can sit while your wallet and hands take a rest from the last project that didn't quite get finished on that 3 day weekend. Things always cost more and take longer the first time you do them. Having some other working vehicle makes life easier since it isn't the big crush to get it running for the Monday morning drive to work or class.
Plan on spending some money on tools it you don't already have them. The stang has both metric and American fasteners, so you really need two sets of wrenches. A timing light, digital voltmeter, vacuum gauge, compression tester, fuel pressure test gauge and fuel line coupler tools are some of the test & tuning tools you'll need. Visit the pawn shops; sometimes you can find deals on tools & test equipment if you stick to well known name brands.
A sheltered work area is almost a must, someplace that you can leave the car in pieces without upsetting anyone. Some guys here have changed a transmission in the parking lot of their apartment in a rainstorm, but they will tell you it wasn't fun. Depending on where you live, a warm dry garage is a nice place to do the winter projects that stangs tend to become.
EFI (Electronic Fuel Injection) Computer - every stang after 85 has or had one: don't let it intimidate you. The computer based EFI systems are not hard to fix and most of the time they tell you what's wrong with the engine. Here's a book that will get you started with how the Ford electronic engine control or "computer" works.
Ford Fuel Injection & Electronic Engine Control 1988-1993 by James Probst: ISBN 0-8376-0301-3.
It's about $35-$45 from Borders.com see http://www.amazon.com/ . Select books and then select search. Use the ISBN number (without dashes or spaces) to do a search
Use the ISBN number and your local library can get you a loaner copy for free. Only thing is you are limited to keeping the book for two weeks. It is very good, and I found it to be very helpful.
For lots of great ideas and tech notes on upgrades and repairs, be sure to check
out http://forums.stangnet.com/showthread.php?t=643651 “Useful Technical Thread Index” sticky at the top of the 5.0 Tech forum.
Things that break often:
T5 5 speed manual transmission (syncros go bad, mostly 3rd gear)
TFI Module (Thin Film Ignition module - mounts on the distributor)
Electric door locks (see the link in my sig for a cheap & easy fix)
O2 sensors(oxygen sensors) They are good for about 60,000 miles and start to go downhill after that.
TPS Sensor (Throttle Position Sensor) causes flaky problems with idle & acceleration.
Fog lights -they overheat the wiring and cause the headlights to flicker. The fix is cheap and simple if you can do electrical stuff.
Harmonic Balancer – they separate between the hub and outer ring. A harmonic balancer puller is a must have to change it. You can rent or borrow a puller from most of the larger auto parts stores.
Things that are very durable: Engine - as long as it hasn't been abused, it will run good for 150,000-200,000 miles without an overhaul
Rear axle - other than an occasional case of worn clutches in the traction lock, they almost never have problems.
Computer - believe it or not, the computers seldom have problems of their own. Most of the problems are with the sensors and the wiring.
Suspension – the front and rear suspension has very few problems if the car hasn’t been wrecked or seen a lot of drag strip runs. The drag strip runs tend to distort and tear the mount points for the rear axle control arms. Revving the engine up to 4000 RPM and dumping the clutch with slicks or drag radials tends to break things.
Things that don’t break often but are hard to fix:
Water pump mount bolts – they corrode and shear off when you try to change the water pump.
Rear oil seal on the engine – lots of parts to remove to get to a $20 seal.
Power steering pump – the pumps are noisy and the pulley requires some special tools to remove and install. If you have the tools, they are easy to do. Again, the larger auto parts stores will rent or loan the tools for the pulley.
Power Steering rack - it is hard to get the toe in set so that you can drive the car to the shop to get it properly aligned.
Starter – the top bolt is hard to get a socket on if you don’t have the right combination of socket, universal joint and extensions.
Everything considered, 5.0 Mustangs are not hard to work on. They just require some patience and thought before you get started.
Reactions: General karthief
California code specifies it is the sellers responsibility to get the smog cert. I won't look at a car without one and its the first thing I get before putting up for sale. I have heard that you can specify "sold as is" no smog if it is in writing with both signing it making it the buyers problem.
