Low RPM sputtering
theconductor
337
96
74
Roseville, CA
If I step on the gas when the motor is below 2700 rpm my car sputters and pops a little through the intake. Above 2700 it pulls like a mofo.
Could it be the timing? I'm also worried that I'm getting too much fuel at low rpm before the boost kicks in. I have 42# injectors, a 255 fuel pump as well as an inline t-rex. I'm running 5 psi of boost.
Any thought would be much appreciated...
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
attachment.php
attachment.php
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see Equus - Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
Or for a nicer scanner see http://www.midwayautosupply.com/p-7208-equus-digital-ford-code-reader-3145.aspx– It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
Thoughts...
- Backfires are often (not always) timing related
- Base/idle timing could be compromised if the distributor has shifted/moved.
- I would check your base timing with SPOUT removed
- If base timing is OK, then we must 'hope' that your tuner got your timing correct
- Tuner : I would presume this problem was not occuring after you had a chip burned
What has been changed since the tune ?
- Check your fuel pressure - Low pressure can result in a lean fuel mix - Tired pump, clogged filter, bad pressure gauge cycling more fuel back to tank
- TPS is also a good idea as the unit does have a mechanical potentiometer - It's cheap and easy to replace - Use the recommended instructions for install and positioning.
- I'm curious about this RPM threshold - If you're running the car at 3000RPM in second/third gear and cruising - Does the sputtering continuously exist when cruising over 2700RPM ??
-OR-
Does the sputtering occur only when you tip-in (accelerate) ?? If yes, check vacuum lines for cracks or disconnects.
Good Luck
-D
