Hello,
Time to pick the brains of the wise ones again.
I wanted to confirm the wire one would use to wire in a manual switch for the low speed fan setting. I am not wild about using terminal 17 on the CCRM to switch right to high speed.
in lookin at the diagrams in the FAQ, i was unclear which wire is the correct wire to ground to turn on low speed only (the description verbage was different for low speed than high speed on the big diagram with each CCRM terminal labled).
Thanks in advance for any help!
