  • 2005 - 2009 Specific Tech
LT Headers & Full length H pipe HACK job
  • Thread starter Thread starter blacksheep06
  • Start date Start date May 17, 2007
blacksheep06
288
  • May 17, 2007
Yes, I screwed up and bought a MAC offroad prochamber last year and now I want LT's. And what really sucks is that the pipe is welded in place so it's going to take some customization.
How difficult is it going to be to make this work? You know, the prochamber basically has a box on it that serves as the balance pipe. I'm assuming the LT's won't come down that far?
Any advice is appreciated. I just want to find out if the prochamber is still going to function correctly. Maybe I'm over thinking it, but that's better than realizing it won't work right in the middle of the job.
PDXStangDude
163
Tigard, Oregon
May 17, 2007
  • May 17, 2007
I thought MAC made LT's that fit up against the Pro Chamber mid pipes.
retfr8flyr
154
  • May 17, 2007
You are looking at a fairly major job with this. I would sell the one you have a get another for the long tubes.
Earl
speedin gt/cs
12
  • May 17, 2007
Here is your answer:http://www.lethalperformance.com/pa...s-25-offroad-prochamberfor-mac-longtubes.html
blacksheep06
288
  • May 18, 2007
My prochamber is welded to the catback so selling it probably isn't an option. It looks exactly the same as the short prochamber minus the longer pipes, I just figured a good exhaust guy could make it work.
'01 Steed
482
Michigan
May 19, 2007
  • May 19, 2007
You should be able to cut it to length and uses reduction flanges or whatever to get the fit right.
Why is the pro-chamber welded to you catback???
blacksheep06
288
  • May 20, 2007
I installed it and it leaked so I took it to an exhaust shop and they tried reinstalling but it still leaked so I just told them to weld it, I know bad move.
So does the h pipe fit inside the header tubes?
'01 Steed
482
Michigan
May 20, 2007
  • May 20, 2007
No....over. You always want the upstream pipe to fit inside the downstream pipe for best flow.
Depending on the size of the collector, you may be able to expand the h-pipe enough to slide it over the collector. You can get pipe expanders online. I don't what they cost. I borrowed a friend's when I needed one.
Or you could take the pipe to an exhaust shop to open it up. Just make sure you leave enough pipe on it when you cut it.
blacksheep06
288
  • May 20, 2007
Thanks for the info 01steed
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
A
Fox Planning on building my foxbody and was wondering if I can get any tips or anything to watch out for!
  • Angelq1028
  • Oct 31, 2024
  • 2 3 4
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 29, 2025
Robman8028
R
Engine Throwing codes 94, 33, 34, 44, and sporadic engine shutoff.
  • Ryu
  • Oct 9, 2024
Fox 5.0 Mustang Tech Sep 13, 2026
M
  • mnky99
  • Sep 5, 2025
mnky99
M
