Machine shop question
  • Thread starter Thread starter stang1986GT
  • Start date Start date Nov 26, 2007
stang1986GT
143
Charleston, WV area
Nov 26, 2007
  • Nov 26, 2007
Just wondering what you guys have paid for machine work for an engine rebuild? Bored .030, line bore if needed, clean the block, install freeze plugs and cam bearings, basically get the block ready for a standard rebuild.
F
Fox8950
247
Nov 26, 2007
  • Nov 26, 2007
I grabbed a block from a junkyard and had a shop clean it and a set of heads up. Had everything hot tanked/magnafluxed 3 ang. valve job, bronze guides, had my block bored .030 and he offered to put my shortblock together for an extra 100 bucks so I told him to go for it. All in all rebuild kit included, cost me 1100 bucks and had an assembled short block and heads.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Nov 26, 2007
  • Nov 26, 2007
- Bore and Hone with torque plates to 4.030
- Line Hone Block
- Mock-Up and square deck block
- Clearance block for crank and stroke clearance
- Cleaning, cam bearings, and oil galley plugs
- Painted and prepped
This was from Keith Craft for $600. He does TOP NOTCH work.
It cost more than this to get a rebuild though. I also had him balance the assembly (485 rpm), apply rod bolts with heat, assembly fees.
It ended up being in the $1,200 range to their shop and I supplied the parts.
It is a bit more expensive than a typical shop, but I got the 40+ years of quality building with it. The typical wait at their busy shop was 8-10 weeks. I told them I needed it A.S.A.P., and got it in 3 weeks during their racing season.
I
irish
168
Florida
Nov 26, 2007
  • Nov 26, 2007
Freeze plugs are so easy to install I would not pay anyone to do it, so are cam bearings but you need a damned expensive single purpose tool. I paid nothing for a motor, tore it down and brought them the pieces(usually shops will charge for disassembly). They cleaned up the block for around 100 and charged 150ish to turn the crank. Cam bearings and freeze plugs cost around 25-30 and usually they will charge you a little to knock them in. I had them blast the oil pan and valve covers and I painted them and the block. They did charge me a little(25) to clean up the pistons as they were factory forged and worth saving. Not that I'm trying to sell it to you but I put the whole lot in the classified for 500. Point is sometimes it is cheaper to simply buy new stuff than refurbish your own and then you can clean up/sell your old stuff and recoup some money. Thats how I like to do it anyway.
Matt
stang1986GT
143
Charleston, WV area
Nov 26, 2007
  • Nov 26, 2007
Ok, thanks for the replies guys. Figures something would happen to the car around Christmas...lol.
Fast63
717
  • Nov 26, 2007
I paid $110 for a bore and $17 for installing new cam bearings. Do the freeze plugs yourself.
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
My next project , a 428 build!
  • horse sence
  • Jul 29, 2026
  • 9 10 11
5K
Classic Mustang Specific Tech Yesterday at 1:24 PM
horse sence
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
D
First post 289 rebuild question!
  • Ddyer2868
  • Nov 24, 2025
Classic Mustang Specific Tech Dec 5, 2025
rednotch
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
