MAF question
02SaleenS281
I need to get a new MAF, it looks like the Lightning MAF is what everyone is using......whats my best choice? Pro-M...C&L....LMAF???? (I'm guessing I need a blow-thru, it's mounted after the blower) btw...the car is an '02 Saleen S281...and has a D1-SC Procharger (8# pulley)
I believe Pro-M is out of business, and avoid C&L at all costs. The other choices you have are the LMAF, and the SCT Meters. Both are good, but the SCT meters will allow you to make more power before maxing out. Both will max out sooner as a blow thru than a suck thru.
Kilgore Trout said:
Have you datalogged the MAF to see if it is pegged? Also, you will need a tune if you change MAF.
I'm still installing the blower right now, I just wanna get the right parts on before it goes to the tuner, because it's a few hours away....it's kind of a catch 22, I won't be able to drive my car hard cause it only has a base tune, so how will I know if the MAF is pegging?
I have dynoed both the pro-m (Professional mass air meters now) and the C&L....The pro-m with a tune will actually net you about 4-5 more HP and abou 10 more rwtq.......on the dyno back to back it made that much difference.....I was using this with the AFM power pipe with a NA set up! Pro-m has a better meter and reads the voltage better than the stock meter.....Actually had to retune the different meter right there also.....
"ED"
